Vritual villagers 4 walkthrought
Talk here about the other games you like.
<<< T.O.N.I >>>
PostSun Dec 28, 2014 7:44 pm
1.first of all your going to make a campfire so locate a black spot which can be found over a big short stone when you go there near the camp fire spot you have some firewood drag a villager there if thr villager haves succes he will pick up some firewood a bring them to the camp fire spot and than near that you also have dry grass drag a villager to that spot and it will bring dry grass after that drag a villager at the camp fire and he will try to start a fire if he doesent have any succes drag again the same villager until he haves succes and there you have it the camp fire...
2.second thing you going to do is dont let your villagers die for hunger so find the berry bush which is located under the research center and near the dead stalks and bannana tree...after you find it drag a villager to the berry bush and if he doesent have succes do it again with the same villager until hehas succes and than the villager will start picking up the berries and bringing it to the food bin...there that will help your villagers to survive for a few days....
3.the third thing your going to do is drag a villager to the research center which is over the berry bush and if he doesent have succes your going yo try again... When he haves succes he/her will start to research and you will gain tech points which is nedded to upgrade your technology...
4.the fourth thing your going to do is drag a villager or two if you want faster progress and take them to the love shack and if they have succes they will start building it and for about a half hour or more the love shack construction will be completed...
Drag a male villager to a female villager and they will embrace and possibly go indoor's if not try again and when they go indoors they might make a baby...
More population can be possible if you build more huds...
Puzzle 1
1.the cuting tool :
First thing your going to do is find the big dead fish which is located near the sea drag a villager on the dead fish bone and he will take a bone and heat it in the camp fire after about one minute the bone will heat and than he will start to sharpen the bone in too a cuting tool and he will bring it to the research center...and there you have it cuting tool...
Puzzle 2
2.the stream:
First thing your going to do is find the waterfall which is located near the tree of life after you find it drag a villager and if he isnt succesfull try again until he will start clearing debris and i think the time of clearing of a single villager is about 1-2 hours after debris is cleared...than drag a villager who is both adept sciencetist and  adep builder to cary the keystone which is located under the debris you cleared and he will take it near the tree of life and plug a hole and the stream will continue to go over the rock and than go near the banana tree...there you have it puzzle 2 unlocked...
Puzzle 3
Boiling water:
First thing your going to do is Find the fresh water pots which is locaded near the stream or under the stream(near the sea)...and than drag a villager to the water pots and he/she will pick it up and fill it will salt water (sea water) and he will bring it to the big bowl on the research center and he will fill the bowl with it...after that find the rocks which is located to the end of the little bringe near the research center...after you find it drag a villager on the rocks and if the villager haves succes he will pick up the rock and take it to the camp fire to heat it...after about 30-60 seconds the rock will heat and turn red drag a villager to pick it up and take it to the big bowl on the research center and there you have it boiling water...
Puzzle 4 soap invented
For this you need to have the boiling water ready and you need to collect 3 herbs(flowers) which is a white flower which is located down the little bridge...really easy to find its really visible...you need to collect 3 herbs...after you done that drag the villager by the herb table which is located near the boiling water pot on the research center...and in like 1-2 minutes the soap making will be done...puzzle 4 unlocked...
my hero's on this forum-----> multipackwolf...twelvefot...2539Woo,stuart98 and of course pixbits...
Return to Other Games
Users browsing this forum: No registered users and 4 guests
