My Parkour Map Coming Soon. SLOW PROGRESS!
Our Minecraft forum! Feel free to discuss Notch's creation here
Kkflarg
Re: My Parkour Map Coming Soon. BETA TESTERS CHOSEN!
PostWed Jan 02, 2013 4:35 am
Darn, missed it...
beta tester
GC:Kkflarg
PROUD MEMBER OF THE LEAGUE OF EVIL
play mah games!-https://sites.google.com/site/pixelancheproductions
PostWed Jan 02, 2013 5:23 am
I'll add an extra slot for you :D
Softkey3
PostWed Jan 02, 2013 10:08 am
I thought this was over exposed topic? I'm confused
Everything is possible,it just depends how far you want to prove it !
My YouTube subscribe if you like and want to see more
My game center name is Softkey3
don't stalk me online Chris
PostWed Jan 02, 2013 11:21 am
I am Ov3rExposeD12Xen0 :rotfl:
I got my Name Changed :asd:
Softkey3
PostWed Jan 02, 2013 12:53 pm
Ahh I see
Re: My Parkour Map Complete! Coming Soon!
PostFri Jan 11, 2013 8:13 am
Map Coming Soon! One more Bug :)
Then release!
It's either Really hard or I suk at it :asd:
PostTue Jan 29, 2013 8:51 am
Bad news :( my Minecraft keeps crashing so I might lose my worlds. That could mean the Map is gone :(
PostWed Jan 30, 2013 7:40 am
Maybe the next update will fix it.
PostWed Jan 30, 2013 7:52 am
Multipackwolf wrote:Maybe the next update will fix it.
Yup! I just have to add some signs and then the map will be released :)
PostFri Feb 01, 2013 9:12 am
Haha xD well the update fixed it but with the bug where half of time stuff doesn't save it is really hard to add anything. So when 0.6.1 comes out "HOPEFULLY" the bug is fixed. And I believe that it won't be, but if it is that's great and it should be Complete :)
Kkflarg
Re: My Parkour Map Coming Soon. DELAYED UNTIL 0.6.1!
PostSat Feb 02, 2013 3:49 am
Its out now :)
beta tester
GC:Kkflarg
PostSat Feb 02, 2013 6:38 am
It is but... (My luck is so bad) I can no longer do it because iMCPEdit no longer works. This means when I need lava, water, food etc i can't hex it in. So until I find a solution I'm pooped :(
Softkey3
PostSat Feb 02, 2013 8:57 am
0.6.1 is out!!!
Re: My Parkour Map Coming Soon. SLOW PROGRESS!
PostWed Feb 06, 2013 10:21 am
Progress has continued but its slow. Hexing in items is a pain! Lava and Water... No problem. But food hexing is annoying. DAMN IMCPEDIT :(
On the bright side it's 75% done :)
PostWed Feb 06, 2013 11:49 am
Mate, Hexing in ANYTHING is easy. Remembering a damage value though? Now that's one thing I'm never going to remember. I use Minecraft Explorer for the item ID, then a HEX converter to convert it into HEX decimal, then I imput that. It's simple.
PreviousNext
Return to Minecraft
