Minecraft ores
Our Minecraft forum! Feel free to discuss Notch's creation here
Softkey3
Minecraft ores
PostSun Feb 17, 2013 10:19 pm
Is it just me or do some of the minecraft ore seem to be upside down?
Everything is possible,it just depends how far you want to prove it !
My YouTube subscribe if you like and want to see more
My game center name is Softkey3
don't stalk me online Chris
Re: Minecraft ores
PostMon Feb 18, 2013 12:58 am
Erm, it's either you or a texturepack. It jeust depends on which direction you approch the block.
Softkey3
Re: Minecraft ores
PostMon Feb 18, 2013 8:10 am
I'm using default and I have noticed some ores in mcpe are upside down
Re: Minecraft ores
PostTue Feb 19, 2013 2:57 am
Well, they all seem the same to me. Up the right way.
Softkey3
Re: Minecraft ores
PostTue Feb 19, 2013 7:51 am
They are like that too in mcpe ill post screenshot
Softkey3
Re: Minecraft ores
PostTue Feb 19, 2013 7:53 am
Ill post a screenshot from the PC later
Ozvooky
Re: Minecraft ores
PostTue Feb 19, 2013 8:26 am
Ok, haven't played mc PE in a while. I think it's been sort of ruined... With stone cutters, using quarts and making the nether thingy weird... I don't like it much anymore. I still like the PC version though
Softkey3
Re: Minecraft ores
PostTue Feb 19, 2013 6:50 pm
It mean you can't get half the blocks in the game until you get the nether reactor
MSN newsblogs[bot]
Re: Minecraft ores
PostTue Feb 19, 2013 9:40 pm
Searching databases...
1 result found .
Ores can change orientation when using Optifine mod for minecraft 1.4.7
Softkey3
Re: Minecraft ores
PostTue Feb 19, 2013 11:05 pm
That may be it actually that is the only mod I have installed,
Re: Minecraft ores
PostTue Feb 19, 2013 11:11 pm
What does optifine do?
Re: Minecraft ores
PostTue Feb 19, 2013 11:15 pm
Decreases LAG, boosts framerate, Allows you to Zoom-In when you press Ctrl.. Erm... Allows you to use 32x32 or higher texturepacks without needing to patch them... ummm.. Lots more things
Re: Minecraft ores
PostTue Feb 19, 2013 11:16 pm
Oh. I've never used it before.
Re: Minecraft ores
PostTue Feb 19, 2013 11:38 pm
It's helpful for bad PC's and for some good ones... I just use it so my framerate isn't jumping everywhere, And So I can zoom in.
Ozvooky
Re: Minecraft ores
PostWed Feb 20, 2013 6:43 am
MSN newsblogs[bot] wrote:Searching databases...
1 result found .
They can? This is one smart bot! And helpful too
Return to Minecraft
