Minecraft RAM
Our Minecraft forum! Feel free to discuss Notch's creation here
ZombieJack
Minecraft RAM
PostSat Jul 13, 2013 7:52 pm
I have Windows XP 32bit and I want to increase allocated memory for Mimecraft I can't go past 494 mb. I want 1 GB so I can play Feed The Beast without lag. I know you cant go past 1 GB on 32bit but I can't go past 494 mb. Even Addtional Java codes don't work. :afraid:
Junk Jaaaaaaaaaaaaaaaaaaaack X.
Nothin' can stop me playin' Junk Jack.
ddawg77
  • Location: If you're looking here, there's a 97.8% chance that you're a creeper
Re: Minecraft RAM
PostSat Jul 13, 2013 8:57 pm
Trust me, minecraft will lag like crap, even with 1 gb. 2 gb or more is recommended.
If you have any questions or comments I will be glad to help! :)
Re: Minecraft RAM
PostSun Jul 14, 2013 12:43 am
I generally play on the default 500mb, I have no issues with lag.
However, since 1.6 made mods more annoying to install, I switched to the Magic Launcher If you go into Setup and then Advanced, you can put more RAM into Minecraft that way, And when I do that, I put in 1500mb (That's 1.5GB) of RAM in.
Cubanjack
Re: Minecraft RAM
PostSun Jul 14, 2013 2:30 am
i love magic launcher
If You Feel Sad, Hug A Penguin, It Will Make Life Better
Join The Penguin Cult! Members: 19
My SKyrim Mods!
My Penguin Tumblr
Lone trainer: Empoleon
Steam: Rakuza (demon head profile pic)
Gamecenter: Rakuza127
Re: Minecraft RAM
PostSun Jul 14, 2013 9:35 am
Same :asd:
ddawg77
Re: Minecraft RAM
PostSun Jul 14, 2013 1:01 pm
Meh, I ended up screwing around too much with magic launcher and messed up minecraft, and it was this big ordeal. I couldn't just "force update" lol. Then just recently our PC got malware and the geeks fixed it but "forgot to back up our PC", so I lost all my minecraft worlds, one of which I defeated the ender dragon and had 5 stacks of iron and like 40 diamonds etc. etc. and it was all legit.
You had one job. :no:
Cubanjack
Re: Minecraft RAM
PostSun Jul 14, 2013 5:49 pm
I actually added like 2 gigs of ram to minecraft
I made a text document and typed in this
java -Xmx2048m -Xms2048m -jar "Minecraft.exe"
if you want 1 gig replace 2048 with 1024. and name the document Start Minecraft.bat
My SKyrim Mods!
My Penguin Tumblr
ZombieJack
Re: Minecraft RAM
PostMon Jul 15, 2013 9:37 am
You can't put more than 1 GB of RAM in Minecraft if you have 32bit Windows.
Ok, lag was caused by my AVG Anti Virus. It started to scan my computer and that was causing the lag.
Cubanjack
Re: Minecraft RAM
PostMon Jul 15, 2013 4:35 pm
O yeah i have 64 bit, how much Ram in total do you have, i have 6 gigs
My SKyrim Mods!
My Penguin Tumblr
Re: Minecraft RAM
PostTue Jul 16, 2013 12:39 am
ZombieJack wrote:You can't put more than 1 GB of RAM in Minecraft if you have 32bit Windows.
I have a 32bit, but I can put 1.5GB into minecraft. But that's because My computer has 2GB all up, which I find is more then enough for everything I do.
Cubanjack
Re: Minecraft RAM
PostTue Jul 16, 2013 12:59 am
2 gigs for me works beautifully
My SKyrim Mods!
My Penguin Tumblr
MinerJack
Re: Minecraft RAM
PostFri Jul 19, 2013 2:41 am
Doesn't FTB allow you to allocate RAM? Anyways, if your PC has atleast 4 gigs, you can run it at 20 FPS or more.
CRACKY IS WACKY!
Cubanjack
Re: Minecraft RAM
PostFri Jul 19, 2013 2:49 am
I like it at around 60+
My SKyrim Mods!
My Penguin Tumblr
Re: Minecraft RAM
PostFri Jul 19, 2013 3:17 am
80+ for me on 1.6
Re: Minecraft RAM
PostFri Jul 19, 2013 10:00 am
If you run it at 60+, then you might want to activate VSync, as your monitor can only display 60 FPS and having it output more will just slow things down.
Return to Minecraft
