LumberJack400 wrote:Nice! I use blender as well. If you need any tips with it I could probably help! Also you'd need to re-map and reimport all the textures if you're swapping from render to cycles because cycles doesn't austomatically import the textures and mapping
Yeah I know how to do that, I've made a minecraft render before. Mostly im trying get the volume scattering to look more like a sky. (Since sun lamps are unsupported with global scattering I have to use a large sphere with emission)
Mostly I had problems with getting torches to look right since using emission uses the transparent part of the texture as well.
