Advertising your adventure maps.
This forum should be used to share worlds you prepared with people.
Lamter
PostThu Jul 04, 2013 11:06 pm
Hey people.
Me and my brother do videos of iPhone games and apps. We are pretty new, and we just started to make Minecraft Videos. Now I think maybe I will make some Junk Jack Adventure map videos. Once the MC videos are up, I will post a link and I will start searching for JJ adventure maps.
So guys;
I don't want to be rude but I probably will not play maps that aren't fun. If you are interested, tell me the name of the map, the download link, creator of the map and a brief description. I hope people are interested in me doing this, otherwise there is no point right :)
Two more things, you can nominate other's maps but I still need their consent. Can people tell me if there is a post on downloading worlds with jailbroken devices, I know how to do it but I realized the way with iTunes looks really complicated to me. If anyone wants me to make a post tell me.
Re: Advertising your adventure maps.
PostFri Jul 05, 2013 10:10 am
viewtopic.php?f=20&t=1816
Made by me.. Made in 1.0.5 (I think) So good luck trying to find someone able to update it!
Slickninja27
PostFri Jul 05, 2013 5:37 pm
U can download JJ maps with a program called "file". U need to download the map by going to safari then downloading it the same way u would on a computer(clicking the download link/button) then it should go to var/mobile/downloads. I'm not exactly sure if this is how u do the rest but try copy and pasting the map u just downloaded into Applications/Junk Jack/Documents. Make sure the world u downloaded is named either world1.dat or world2.dat or world3.dat as long as that world slot is empty. I hope this helps, and do u upload videos to youtube with a display recorder? If so, can u tell what display recorder u use?
Grettir
PostFri Jul 05, 2013 5:42 pm
Pretty Shure you need to be jail broken for that
What happened? Where is everybody?
Lamter
PostFri Jul 05, 2013 8:20 pm
Slickninja27 wrote:U can download JJ maps with a program called "file". U need to download the map by going to safari then downloading it the same way u would on a computer(clicking the download link/button) then it should go to var/mobile/downloads. I'm not exactly sure if this is how u do the rest but try copy and pasting the map u just downloaded into Applications/Junk Jack/Documents. Make sure the world u downloaded is named either world1.dat or world2.dat or world3.dat as long as that world slot is empty. I hope this helps, and do u upload videos to youtube with a display recorder? If so, can u tell what display recorder u use?
Its called iFile. there is MyFile too I think... I know how to do it but I am asking if anyone doesnt
Edit: I will see what I can do with your map MultiWolf
Slickninja27
PostSat Jul 06, 2013 4:01 am
I meant to say ifile... But it auto-corrected me...
PostSat Jul 06, 2013 8:19 am
There's only one Display Recorder
Lamter
PostSat Jul 06, 2013 4:58 pm
Display recorder cracked by Sinful iPhone repo.
PostSun Jul 07, 2013 8:28 am
Annnnd that is the worst display recorder you could get. :| The legitmate one works without any issues at all. All cracked ones just don't work well.
Lamter
PostSun Jul 07, 2013 5:07 pm
it works well for me. I don't have any problems with it.. Except sometimes audio issues, but that's easily solvable
PostSun Jul 07, 2013 10:19 pm
It's still the worst type you can get, and I think you'll find When display recorder updates, you'll have lots of issues for awhile. The proper one has no issues at all
Lamter
PostMon Jul 08, 2013 11:04 pm
Display Recorder by.. which one? All the same?
PostTue Jul 09, 2013 12:36 am
Wut.
The Display Recorder from the BigBoss repo is the proper Display Recorder. By using any other one, they could install basically anything on your device.
Slickninja27
PostMon Jul 15, 2013 5:57 pm
I just can't find one that uploaded videos to YouTube for some reason. Every display recorder when I tried to upload a video it would just say copied to clipboard and nothing happened... :|
PostTue Jul 16, 2013 12:41 am
You need to sign in in the "Settings" app. Scroll to the bottom and go into Display recorder, then go to the bottom of that.
Return to Adventure Maps
