Disabling Hacked Files Error v1.1.2
This forum should be used to discuss and share mods of Junk Jack (textures, or whatever)
kivifreak
PostSat Mar 16, 2013 6:26 pm
Disable Hacked Files Error! version 1.1.2
for Junk Jack v1.2.4
Remember this Error:
For iOS 5 and higher.
Well with this tool you will disable the Hacked Files Error and you still can play the game :)
The error will still show up, but you can play the game ;)
This tool CAN'T damage anything of your Junk Jack files!!!! So no need to worry ^^ :asd:
Update Log
Version 1.1.2
Fixed some File Bugs.
Version 1.1
Added .plist for older devices, Jailbreaks.
Your iPhon/iPad/iPod must be Jailbroken
Jailbreak here
Auto Installer Cydia:
(This)
This is the easy part ^^
1) Add this repo to cydia
http://cydia.myrepospace.com/kivifreak/
2) Download Junk Jack Disable Hacked Files from the repo!
3) After downloading RESPRING your iDevice for it to be enabled!
Respring for example with WinterBoard or SBSettings.
Manual Installation:
1) Download the .dylib here:
Download Here
Download the (NEW) .plist here:
Download Here
2) Place the .dylib to /Library/MobileSubstrate/DynamicLibraries/
3) Respring your iDevice
You are done ^^
What can i do with this?
Well now you can modificate every .json and the data.dat in Junk Jack with afterwards playing ^^
I will upload some mob spawn rate mods soon :)
Btw this is jus a little exampl of what you can do with MobileSubstrate ;)
Uninstall
Simply delete the
/Library/MobileSubstrate/DynamicLibraries/JunkJackExtra.dylib
Bugs
The only bug is that the message will still appear. HEUREKA XD
This tool should work with every version of Junk Jack currently avaiable!
kivifreak
Re: Disabling Hacked Files Error v1.0
PostSat Mar 16, 2013 6:41 pm
jerzeeshadow wished me luck and look what i did with it ^^
PostSat Mar 16, 2013 10:46 pm
:hail: I need to start learning coding!!!
kivifreak
PostSun Mar 17, 2013 6:02 am
haha lolz ^^
its mainly objective C and Assembler: ARM
PostSun Mar 17, 2013 8:06 am
Nice, Ima go test this...
kivifreak
PostSun Mar 17, 2013 8:46 am
Multipackwolf wrote:Nice, Ima go test this...
dood it works ;)
1) RESTART THE SPRINGGBOARD (srsly elsewise MobileSubstrate won't load the tweak ;) )
2) The message shows up but it still works.
3) If you edit the data.dat or the map.json the wrong way (OF COURSE IT CRASHES) :3
For example change the chance of Snowy Bush in map.json to 0.60 and you will see if you generate a world you can still play it etc.
(Or change the count of the Jack Statue to 100 and change the ymin and ymax to the same level ;) )
PostSun Mar 17, 2013 9:07 am
Dude, I was one of the first people to find the map.json and find out how things work - I know how it works...
kivifreak
PostSun Mar 17, 2013 9:14 am
Ehrrm... I missunderstood the conversation. Sry ^^'
PostSun Mar 17, 2013 9:16 am
I know :| I read the post.
kivifreak
PostSun Mar 17, 2013 9:19 am
oh ok sry :3
Anyways i could show you some stuff and how it works if youre interested. (i could also edit UI)
Btw i will release version 1.1 which deletes the message soon.
jerzeeshadow
PostSun Mar 17, 2013 9:22 am
Yes, yes! Do tell us master kivi....
Currently Searching For Video Game Treasures, Wanna Trade?
My Ultimate Achievement: 100% Empty World (O. Junk Jack!)
Check out DC: http://dragcave.net/
PostSun Mar 17, 2013 9:40 am
I'd be happy to see any other mods :P BTW I just put a banner on my YT page, hows it look?
kivifreak
PostSun Mar 17, 2013 9:45 am
jerzeeshadow wrote:Yes, yes! Do tell us master kivi....
Derp i'm not a master XD
Well usually when i use MobileSubstrate i would decrypt the app and use theos afterwards. Now i only use theos for the nic.pl and i use Flex (weird app) to get the MS methods. Basically Flex makes contact with Junk Jack and reads all public stuff that you can change from outside the game. One of them is jsonHacked in DigAppDelegate. The app delegate usually gets called when you start the app. Using Flex you can only change simple stuff for example booleans, int, void (int).
With theos nic.pl you can add code into the method. So you are telling Junk Jack what to do ;)
Also in DigAppDelegate there is the -(void) showAlert:(id) that you could change with theos.
There are good tuts on magicios.org
jerzeeshadow
PostMon Mar 18, 2013 12:28 pm
IDK, it's still not working for me....
It still stops after the hack warning. Maybe it's because I'm on iOS 4.2.1/2nd Gen iTouch?
The .dylib file is installed in the MobileSubstrate folder. And I have updated MobileSubstrate through Cydia.
Also, I've tried editing the Map.json with iFile's text editor. If that has any ill-effect.
Has anyone else had success?
kivifreak
PostMon Mar 18, 2013 4:36 pm
jerzeeshadow wrote:IDK, it's still not working for me....
I had succes :3
Have you resprung your iphone after the installement?
Return to Modding
