CrossHair Template Maker Needed.
This forum should be used to discuss and share mods of Junk Jack (textures, or whatever)
JunkPix
PostSat May 25, 2013 4:52 pm
I Tried Making but I Always Failed, And Yes, Im :no: Angry
Can Anyone Make a blonde boy teenager CrossHair ?
Email Me: CarlZornosa@Yahoo.com
Thank You. :byebye:
raniadoll
Re: CrossHair Template Maker Needed.
PostTue Aug 27, 2013 8:48 am
I am new and I need to know how to change my skin without jail breaking on my iPod. Also I have a computer. I think I need a computer for it.
rania
ALCRON
PostTue Aug 27, 2013 10:49 am
What version of iOS are you running rania? Higher then iOS 5 (not sure about exact version numbers) and replacing files un-jailbroken will not work, as files are read only past that point.
Otherwise, you can use a program such as iFunBox or iExplorer* to replace the file named crosshair.png with a modified version, which SHOULD change your characters look, if not make sure you don't have any hats enabled.
* I have rather limited experience with iExplorer, so I dunno how well it works.
PostTue Aug 27, 2013 6:25 pm
Anything iOS 5 will work. iOS 6 doesn't work, unless jailbroken.
Return to Modding
