Multipackwolf wrote:I meant it in a light hearted kinda of way. I had a little go with trying to add stuff through the .jsons, it worked quite well, however nothing actually did anything. A mob would be impossible with just the .json or .dat files - you need access to the actual code to do it.
I know you've might have said it in a light manner, but i just getting negative vibes from you dude and really i'm not trying to be the bad guy on the forum..
I've never modded or have never been deep in scripting and coding i stay away from most pixel sprite styled games because there more difficult to mess with than, if i wanted to open up fallout 3 modder kit and mod that..
maybe in junk jack x they will release some sort of open source engine/ sdk that allows you to simply create mods using sprites codes and what not
