How To Edit Textures
I haven't really seen a tutorial on how to edit textures and other things so I decided to make one myself.
Things you need:
What you do:
Uploading Your Textures:
Downloading Other Textures:
Original Textures:
PLEASE tell me or PM me if you or confused, you see a problem, something needs to be added, or you need help.
Things you need:
- Open Spoiler
- 1. You need a program like iExplorer or i-FunBox.
-I personally like i-FunBox but iExplorer looks good as well.
2. You need a computer.
3. A cord to connect the computer to the ipod/iphone obviously.
4. A picture editing program.
-Photoshop is good but things like Gimp work too.
5. An iDevice with Junk Jack installed.
What you do:
- Open Spoiler
- 1. You need to download the Junk Jack textures at the link at the bottom of this post under the spoiler.
-Make sure you get the right version. The other ones are just to look at. I also recommend only downloading files you will use like don't download iPad files if you don't have an iPad.
2. Next, you can edit these pictures to however you want them to be with your photo editing program.
3. Save the edited pictures in some folder where you can access it.
-Make sure to save them as "png." files so they work right.
4. Open up i-FunBox, iExplorer, or any other program you might be using.
5. Open up your edited textures in whatever file you have it in.
6. On i-FunBox, you click on "User Applications" somewhere on the list to the left.
-I'm assuming it is about the same with iExplorer and other file programs.
7. On i-FunBox, your apps should show up on the right window. Click Junk Jack from your apps.
-Once again I'm assuming it's about the same with iExplorer and other file programs.
8. On i-FunBox, you should see some Junk Jack files and a picture of Jack as well. Click on the picture of Jack.
-It should be called "JunkJack.app" in i-FunBox. In iExplorer or whatever program you are using, if you were able to find Junk Jack and everything, it should be the same file name you are looking for.
9. Once "JunkJack.app" is opened, go back to your edited textures in your files and drag them from your files, into the i-FunBox window on the right.
10. Wait for the thing to load the pictures, then go to your iDevice.
11. Double click the "Home" button and hold the Junk Jack app located on the bottom of the screen until it starts shaking, then press the delete button on the top left.
-This step is only if you played Junk Jack recently and if you have an iDevice with multitasking.
12. Open Junk Jack and try out your new stuff.
- Open Spoiler
- 1. Go to http://www.mediafire.com/ and make an account.
-If you have one already then just log in.
2. Upload ALL of your files that you edited.
-They should be "png." files.
3. Make a new folder in MediaFire and name it whatever you want.
4. Put all the files you uploaded in that folder.
5. Share the link to that folder on the forums for us to enjoy too.
- Open Spoiler
- 1. Download the file from whatever link provided.
2. Open i-FunBox, iExplorer, or whatever other program you might be using.
3. Open the textures that you downloaded in whatever file you stored them in.
4. On i-FunBox, you click on "User Applications" somewhere on the list to the left.
5. On i-FunBox, your apps should show up on the right window. Click Junk Jack from your apps.
6. On i-FunBox, you should see some Junk Jack files and a picture of Jack as well. Click on the picture of Jack.
7. Once "JunkJack.app" is opened, go back to your edited textures in your files and drag them from your files, into the i-FunBox window on the right.
8. Wait for the thing to load the pictures, then go to your iDevice.
9. Double click the "Home" button and hold the Junk Jack app located on the bottom of the screen until it starts shaking, then press the delete button on the top left.
10. Open Junk Jack and try out your new stuff.
Original Textures:
- Open Spoiler
- v1.2 (Currently Current Textures)
http://www.mediafire.com/?c7k3g1lrp5ucu
v1.1
http://www.mediafire.com/?0915npbgkdrhs
V1.0.5.1
http://www.mediafire.com/?zpwna7dhp6q10
