Edit Textures Guide
This forum should be used to discuss and share mods of Junk Jack (textures, or whatever)
Was this tutorial useful?
Yes.
63
61%
No.
4
4%
It was somewhat useful.
11
11%
I'm still very confused.
25
24%
Total votes : 103
cptjason
Edit Textures Guide
PostSat Feb 23, 2013 3:05 pm
TwelveFoot wrote:Yeah, I tried that too.
Once I changed the texture in the .app on the computer iTunes wouldn't accept it.
It will work,
You need to be jailbroken and you need to install a tweak and app from cydia that involve pirating :s
Re: Edit Textures Guide
PostSat Feb 23, 2013 11:57 pm
No, you need to just install appsync
cptjason
Edit Textures Guide
PostSun Feb 24, 2013 1:14 am
Multipackwolf wrote:No, you need to just install appsync
Same sh*t!
And there is no denying that it is mostly used for installing cracked applications!
PostSun Feb 24, 2013 1:26 am
No, it's not the same. Appsync allows you to install modified apps, yes, they can be cracked ones, but like with our Texture Mod problem, we can use it for that. It's also used for apps that are not on the appstore, or in other words, apps you made yourself. I have it so I have less issues with Beta. There have been loads of reported cases to TestFlight about beta's not working, they say it's because your Jailbroken, I say it's because they are Jailbroken, without AppSync.
PostSun Feb 24, 2013 5:11 am
The beta works fine on my jailbroken iPod
PostSun Feb 24, 2013 9:14 am
Same with me. It's just in-case though.
PostSun Feb 24, 2013 8:50 pm
Multipackwolf wrote:It's a .ipa :facepalm:
Yeah, that.
And what is installing a tweak on my iPod going to do about iTunes (on computer) not accepting it?
PostMon Feb 25, 2013 5:42 am
After you install it, you use ifile's 'AppFastIn" And it should work. You can't take it through iTunes... Because iTunes SUCKS.
JunkLump
PostMon May 27, 2013 6:59 am
Should i post a tutorial on how to edit/download/install textures with just an iPod/iPhone? Has anyone done one?
iPod touch 4th gen, 6.0.1
Jailbroken
No computer.
PostMon May 27, 2013 10:56 pm
I did on youtube... You can try and find it if you want :sisi:
redredret
PostSun Jun 30, 2013 5:16 pm
it doesn't work! :(
i prayed to god and asked him for a bike, but i knew it didn't work that way so i stole a bike and asked him for his forgiveness.
click the egg please
thekidmen10
PostSat Dec 13, 2014 9:19 pm
MisterTacos wrote:Woah... Just noticed this got stickied. Thanks PixBits! :)
hiw can you tell its stickied?What does stickied mean :3
my 3DS FC:4957-5104-9171 Image
PostSat Dec 13, 2014 9:34 pm
MisterTacos doesn't come 'round here anymore. He'll never answer you. :P
Stickies have the green slime on them, and it means they can't fall to the bottom of a category.
Previous
Return to Modding
