Jus to clear stuff up i've done lots of texture edits hex edits and co on minecraft pe (even modding on jailbroken device), you sadly can't overwrite stuff that isn't in the Documents folder (and in the library folder) since 0.6.0 The only way to fix this is jailbreak the device and use ifun-box or iExplorer then as usually. Sorry for that If you need an explanation for this open iExplorer browse your Backups -> go to com.jack.xsx.junkjack You will see only overwriteable content.
Don't erase it. If you have a device that allows multitasking you must completely close the app (double tap home button, hold on app, press red minus), after installing the texture.
1.Junk-Jack-Wiki 2. The world is big, 256 blocks high and 768 across. 3. Who is John Galt? 4. Lack of objection does not indicate consent. 5. We scream, we shout, we wail, we cry; but in the end we all must die.
