The Void (by JerzeeShadow) with no BG layer + Cloth Floor
This forum should be used to discuss and share mods of Junk Jack (textures, or whatever)
kando
PostTue Jul 17, 2012 9:23 pm
No bedrock, all replaced with red cloth. To welcome you in, you start at the top with the sun and have a nice drop to the ground level.
Note, if you dig through the bottom of the world and jump in, JJ will crash :teach:
also note, the sky background does not reach most of the bottom 80%+ of the world.
http://www.sendspace.com/file/8vp077
kando wontu
World Hacker/Hexer & Wiki Admin/Contributor
Light World Mods: http://tinyurl.com/9zxxfvs - http://tinyurl.com/96ymxkb
63 Hearts Mod: http://tinyurl.com/9avfkjt
"UNOFFICIAL" Chat: http://tinyurl.com/9lmexcn
Re: The Void (by JerzeeShadow) with no BG layer + Cloth Floo
PostTue Jul 17, 2012 9:26 pm
You actually replaced bedrock with cloth... bad things may happen now.
What happens if you break the cloth blocks so there's a hole down?
kando
PostTue Jul 17, 2012 9:29 pm
TwelveFoot wrote:You actually replaced bedrock with cloth... bad things may happen now.
kando wrote:Note, if you dig through the bottom of the world and jump in, JJ will crash :teach:
All that happens is you lose any change you made on that particular map since the last time you hit the pause button.
No real harm :approved:
kando wontu
Molotov13
PostTue Jul 17, 2012 10:28 pm
You could just Change the texture so the background isn't there. You didn't have to hex edit it, it took me 10sec to do it with both rocks.png and rocksmini.png
[GC: SladeMolotov13]
EpicTurdle
PostThu Jul 19, 2012 3:25 am
Wow nicely done.
This was created far faster than the other empty world and is far more "empty" than the previous one as well.
Really cool, this can allow for some really fantastic adv. maps.
kando
PostThu Jul 19, 2012 1:11 pm
I just modded his...it still has the same amount of blocks not destroyed in the world (like 8-15), but thanks :P
Getting kind of bored tho, only so much you can do...would be much easier and more fun to just be able to edit json files :Prrr:
kando wontu
Return to Modding
