help me
This forum should be used to discuss and share mods of Junk Jack (textures, or whatever)
safe898
help me
PostWed Jul 18, 2012 4:36 pm
how do u put a texture pack on your junk jack
awsomeaustin13
Re: help me
PostWed Jul 18, 2012 6:12 pm
1. Download the file from whatever link provided.
2. Open i-FunBox, iExplorer, or whatever other program you might be using.
3. Open the textures that you downloaded in whatever file you stored them in.
4. On i-FunBox, you click on "User Applications" somewhere on the list to the left.
5. On i-FunBox, your apps should show up on the right window. Click Junk Jack from your apps.
6. On i-FunBox, you should see some Junk Jack files and a picture of Jack as well. Click on the picture of Jack.
-It should be called "JunkJack.app" in i-FunBox. In iExplorer or whatever program you are using, if you were able to find Junk Jack and everything, it should be the same file name you are looking for.
7. Once "JunkJack.app" is opened, go back to your edited textures in your files and drag them from your files, into the i-FunBox window on the right.
8. Wait for the thing to load the pictures, then go to your iDevice.
9. Double click the "Home" button and hold the Junk Jack app located on the bottom of the screen until it starts shaking, then press the delete button on the top left.
-This step is only if you played Junk Jack recently and if you have an iDevice with multitasking.
10. Open Junk Jack and try out your new stuff.
oxxxxx[=========~ AWSOMEAUSTIN13 ~=========]xxxxxo
JUNK JACK IS AWESOME
GameCenter=DrLambChops
safe898
Re: help me
PostThu Jul 19, 2012 3:47 am
Thank u
Return to Modding
