Junk Builder [World Editor]
This forum should be used to discuss and share mods of Junk Jack (textures, or whatever)
WhiteFang
PostThu Aug 30, 2012 1:31 am
As you know, I am the creator of the "Hotel of Itemness" map (which can be found in my signature) However, I put up a poll to ask people if I should try to make a world editor (As you can tell by the title :Prrr: )
So far, progress is going relatively well, and I'm working a lot on this project.
Right now, I only have one picture, but the program is more about the code then the graphics;
I will release it when I finish it, so, please be patient!
Thanks, Winter_Snake
Beta Testrers:
    - Alcron
    - Tots
    - FlipBeef97
    - Lilromeodude
    - Jerzeeshadow
List of resources:
    • Junk Jack x World/Player Editor: Github
    • Youtube Channel: Winter_Snake
    • Discord: Winter_Snake
Tots
Re: Junk Builder [World Editor]
PostThu Aug 30, 2012 2:06 am
Cool! :approved:
Will this be an app or a computer program?
GC- Tots_32
WhiteFang
PostThu Aug 30, 2012 2:13 am
Tots wrote:Cool! :approved:
Computer. I don't feel like making it an app. It would take so much longer.
List of resources:
PostThu Aug 30, 2012 2:56 am
I don't like the idea, it makes it too easy to get stuff... but guess Pixbits will tell you to stop if they don't want it... I'm not saying it's a bad idea though...
WhiteFang
PostThu Aug 30, 2012 3:55 am
Multipackwolf wrote:I don't like the idea, it makes it too easy to get stuff... but guess Pixbits will tell you to stop if they don't want it... I'm not saying it's a bad idea though...
Thats why I'm still debating wether I'm going to release it to the public or to a certain group. But if you think about it, all this is, is hex editing the world.dat file. And kando is a master at that, so it's not like we haven't past this point. But I still am going to contact pixbits about it and see if they will want me to release it or not.
List of resources:
PostThu Aug 30, 2012 4:07 am
They'd go through the coding, see how it works, fix a few things up, then release it and give you credits for it, other wise it might be a bit of a problem... well that's what i'd do in their situation anyway...
kando
PostThu Aug 30, 2012 12:32 pm
Smart thing to do, but still, I'd like to take a peek if possible :)
PM me if you wouldnt mind sharing, I'd be more than happy to test for you.
Plus, although i cant create an editor from scratch, or anything from scratch, I can modify code once it exists, as well as add onto it.
Cheers!
kando wontu
World Hacker/Hexer & Wiki Admin/Contributor
Light World Mods: http://tinyurl.com/9zxxfvs - http://tinyurl.com/96ymxkb
63 Hearts Mod: http://tinyurl.com/9avfkjt
"UNOFFICIAL" Chat: http://tinyurl.com/9lmexcn
awsomeaustin13
PostThu Aug 30, 2012 6:21 pm
I don't out you guys, but I CAN'T wait for this.
oxxxxx[=========~ AWSOMEAUSTIN13 ~=========]xxxxxo
JUNK JACK IS AWESOME
GameCenter=DrLambChops
WhiteFang
PostThu Aug 30, 2012 6:24 pm
Cheers!
Of course! :approved: Though, I still want to make sure everything works, and finish the basic's of it.
List of resources:
PostThu Aug 30, 2012 10:28 pm
So You would be able to import a world, right? If so, this makes my project much easier.
PostThu Aug 30, 2012 10:33 pm
It would be good for the people who are experianced with the game yes... But im think about the newbies...
I don't see a load world button...
PostThu Aug 30, 2012 10:35 pm
Ah true.
Then it's gonna be limited somehow.
@twelvefoot
Unless it somehow generates it's own worlds the same way as junk jack does, I don't see how it'll work without loading worlds
WhiteFang
PostThu Aug 30, 2012 10:41 pm
p1nkbr0 wrote:Ah true.
@twelvefoot
This is only the main menu. At the
Create World
screen, you will be given the option to save and load worlds to your computer to edit. And also export and import worlds from Junk Jack.
List of resources:
PostThu Aug 30, 2012 11:24 pm
Cool.
Return to Modding
