How to Make/Download a Crosshair Tutorial
Do you find this helpful?
Yes
2
17%
No
2
17%
THANKS!!!
3
25%
YOU SUCK!!!
2
17%
I don't know...
1
8%
I already knew. c:
2
17%
Total votes : 12
PostTue Jan 22, 2013 6:23 pm
Here is the tutorial:
Okay so what you will need is:
1- iFunBox
2- Paint.net
3- Computer
Search the two on Google if you don't know what they are.
Step One: Getting Ready
Find the original Crosshair sprites and save it to your documents on your computer.
With Paint.net, open the picture so it is ready to edit.
Step Two: Ready To Edit
Now that you have your Crosshair ready to edit, you can begin.
In the upper toolbar, you will see an option: Units. Change "Inches" to "Pixels".
Also in the upper toolbar, you will see a dropbar that says "Window". Change it to "500%".
Step Three: The Rest
Now, with everything ready, you are ready to edit your own crosshair!
Select the pencil and your color and begin. It is recommended to start with the head first.
Once you finish the first sprite (upper left), select rectangular select tool (s), select your entire first piece and copy (ctr. + v). The copied version will appear on top of the first so you may have to drag it off.
Then, just replace the other sprites in the first row with the first one!
Do the rest with the same method and save changes when you are finished.
Step Four: Using the Crosshair
Open iFunBox and plug in your device into your computer. Wait until it recognizes your device.
When recognized, go into:
User Applications-->Junk Jack-->Junk Jack.App
Now drag your Crosshair picture into the margin of the graphics in iFunBox.
Wait...
Load Junk Jack.
I hope this helped you all! C:
Re: How to Make/Download a Crosshair Tutorial
PostTue Jan 22, 2013 11:34 pm
If your device supports multitasking, you'll need to completely close the JJ app after putting the crosshair in.
Meaning, double tap the home button, hold on the JJ app, press the red minus sign.
PostTue Jan 22, 2013 11:36 pm
TwelveFoot wrote:If your device supports multitasking, you'll need to completely close the JJ app after putting the crosshair in.
Yeah...what he said.
Republi
PostSun Jan 27, 2013 9:59 am
It doesn't work on my iPod touch 4g!
JunkLump
PostSun May 26, 2013 11:45 am
I have an iPod 4th generation, but its jailbroken so i edit and transfer textures without a computer and just my iPod.
iPod touch 4th gen, 6.0.1
Jailbroken
No computer.
LazerLatte
PostTue Jun 11, 2013 10:58 pm
Umm, whenever I follow this tutorial nothing happens. Like, literally, nothing happens in iFunbox aside from the thing refreshes after pasting/dragging (I tried both) any file. No files are replaced at all. Please help? :o_O:
And yes, I made sure the app was closed in multitasking.
PostTue Jun 11, 2013 11:34 pm
What ios software do you have?
LazerLatte
PostTue Jun 11, 2013 11:44 pm
mastery51 wrote:What ios software do you have?
Umm... I believe 6.1.3.
PostTue Jun 11, 2013 11:56 pm
I'm sorry to say but Apple has removed the ability to change crosshairs with their software updates. Any ios software that is 6.0 or up won't allow you to alter any in game files. The only way now is to be jailbroken. Sorry. :(
LazerLatte
PostWed Jun 12, 2013 12:02 am
D'oh now that just ain't fair >.< last time I jailbroke I couldn't install apps for some reason and I forgot to backup.... I suppose I could try again....
Edit: I jail broke and it still won't work >_<
Edit 2: NVM, it was just a quirk with my tethered jailbreak :dunno:
arachnid14
PostFri Jun 21, 2013 10:13 pm
so what do i do if i dont have a computer or jail broken device plz tell me :hail: :hail: :hail: :hail: :hail: :hail: :hail: :mrgreen:
Add the Falling Star to Junk Jack X!
PostFri Jun 21, 2013 11:39 pm
No computer + no jailbreak = no new textures
Return to Crosshairs
