I have an important question!
PostSun Feb 24, 2013 10:47 pm
Hello. :3 I have a question. Is there a way I can edit Junk Jack textures...on my iPad? Because my computer is "broken" at the moment. Hehe.
Thanks. :asd:
Re: I have an important question!
PostSun Feb 24, 2013 10:51 pm
Yes. You can edit the textures themselves with the app "art studio." You can't install them unless you're jailbroken,
PostMon Feb 25, 2013 5:41 am
I use TinyPixals for the crosshair.png.
However, for it to work properly, your going to need to be Jailbroken, and use myfile to get a completely blank IMG file (make sure it's the same size as the original!) , make your crosshair over the original, use a color that your not going to use at all, and color the transparent bit, and any bits you don't want... Then copy over and drop out the color you chose not to use, and it should work... If your lucky ;)
PostSat Mar 09, 2013 5:57 pm
Thank you! Yes, I am Jailbroken, an I've been searching for months. Erk. Thanks! :asd:
PostSun Mar 10, 2013 9:29 am
No problem!
PostSun Mar 10, 2013 11:22 pm
All the art apps vary in cost.
Tiny pixels is best for small projects. It's really easy to use, but it can be tricky to work with transparencies.
Sprite something is expensive, but it offers animations. It crashes a lot, though, so save often.
Art studio is surprisingly cheaper than sprite something and it's like a low powered photoshop. I like it a lot.
PostSun Mar 10, 2013 11:34 pm
I haven't Tried art Studio Yet, but using Tiny Pixals, Myfile, and Sprite Something together is a useful way to get stuff done. :)
Return to Crosshairs
