Tutorial: How to apply custom crosshairs to hats
LazerLatte
PostSat Jun 15, 2013 11:29 pm
Although this is quite obvious, I've noticed no one has mentioned this.
In the files, there are separate .png's for the hats as the default Jack. They are all right next to said crosshair. Simply find the name of the desired iAP hat to apply a custom crosshair to, and rename the custom one to that. Then just copy and paste it in like normal, and it should work like it usually would with replacing the normal Jack crosshair.
Return to Crosshairs
