Black Sheep Hat!
Killerofsheep
Black Sheep Hat!
PostSun Mar 04, 2012 5:53 am
This changes the colour of the sheep hat to black! Inspired by this post: http://forum.pixbits.com/viewtopic.php?f=6&t=2710
Just put the file in the junkjack.app folder on your ipod!
Download Link: http://www.mediafire.com/i/?f0uwu3xwi8vux6h
Must have bought sheep hat to use.
                  _▉_
⊙_⊙)    (◐_◐ )
Sfoto
Re: Black Sheep Hat!
PostSun Mar 04, 2012 6:18 am
How did you create that. This is a master piece! :hail: :hail: :hail:
Hi there, I am sfoto, and I like investigating!
PostSun Mar 04, 2012 6:43 am
I like your red tools, post a DL link for them?
Killerofsheep
PostSun Mar 04, 2012 6:46 am
The red mithril? Lumps, ingot and block as well?
                  _▉_
⊙_⊙)    (◐_◐ )
Yeah that'd be cool
Killerofsheep
PostSun Mar 04, 2012 6:47 am
Ok itll take a moment to get them...
                  _▉_
⊙_⊙)    (◐_◐ )
Nicodemus82
  • Location: Welsh/Italian guy currently living in Toronto, Canada
PostSun Mar 04, 2012 7:05 am
How did you get that pickaxe?
Member of the Beta Tester Alliance
Twitter http://twitter.com/#!/Nicodemus82
Websitehttp://adeptgamer.com
PostSun Mar 04, 2012 7:07 am
he swapped the the Mithril and the monster pickaxe pictures, i have the actual monster pickaxe though...
Killerofsheep
PostSun Mar 04, 2012 7:08 am
It's a texture not the actual thing. All my picks are unique, using un-implemented ones in the files, they all match the material, the monster pick just happened to suit my red mithril...
                  _▉_
⊙_⊙)    (◐_◐ )
Nicodemus82
PostSun Mar 04, 2012 7:31 am
Dbeck25 wrote: i have the actual monster pickaxe though...
I thought that was what was known as the developer pickaxe..anyways, how did you get it then?
PostSun Mar 04, 2012 7:35 am
hexed it, the code is FE00, it crashes the game when used without the rest of the code though...
Killerofsheep
PostSun Mar 04, 2012 7:55 am
Do you know the code for the cyan and pink pick?
                  _▉_
⊙_⊙)    (◐_◐ )
PostSun Mar 04, 2012 7:57 am
you mean the diamond pickaxe right? or something else... post a picture...
Killerofsheep
PostSun Mar 04, 2012 8:02 am
In tresures.png it is 2 to the right from the copper skull.
                  _▉_
⊙_⊙)    (◐_◐ )
PostSun Mar 04, 2012 8:09 am
you mean this one?
sorry its so small
Return to Crosshairs
