Clone Trooper (Captain Rex)
PostTue Aug 14, 2012 5:44 am
Well this is a clone from star wars. He doesn't have as many effects like Iron Man did though. He flies instead of climbing the ladders, with a jet pack instead of rocket shoes. He also always carries a pistol in one hand that fires while using the action tap and what ever tool or weapon or object he is carrying in the other (so he multitasks a little bit :asd:). So he could have the most epic weapon combination ever ( antanium jewel encrusted sword with a pistol, awesome!!). Also, when jumping he has a small flame that comes out from the jet pack. I might alter the effects a little bit more, make them polished. Also add some things to it ( maybe have bullet shells fall from the pistol ;) ). We'll see though.
Enjoy!
http://www.mediafire.com/view/?01i5aqqbz3490rd#
This one has more effects.
http://www.mediafire.com/view/?f9syl2nxo5x6xyn#
Nixontastic1134
Re: Clone Trooper (Captain Rex)
PostTue Aug 14, 2012 9:27 am
Good work Mastery! :rock: :hail:
dank memes
Hobbes
PostTue Aug 14, 2012 12:24 pm
Cool :D
Got A Problem?
Shoot Me A Message I'll Be Glad To Help You.
ALCRON
PostWed Aug 15, 2012 8:08 am
This looks great with my interface, good job. :approved:
Arslan
PostWed Aug 15, 2012 6:56 pm
YESSS THANKS MASTERY51!!! SOMEONE LISTENED ME!!!!!!! :hail: :hail: :hail: :hail: :hail: :hail: :hail: MY MASTER!! (a little problem: he has 2 weapons the pistol and the tools. looks a bit awkward but EPIC!!!
CHECK OUT MY CHANNEL: http://www.youtube.com/user/Arszilla
Add me on GameCenter: Arszilla!!!!
Thx to mastery51 for my crosshair Captain Rex!!!!!!
PostWed Aug 15, 2012 7:49 pm
:sisi: yeah, there's no way to fix that. That I can think of. Unless we remove the pistol from Crosshair or retexture a weapon or tool but there won't be an animation on the pistol. Plus, I don't really know how to retexture weapons or tools :dunno:.
Arslan
PostWed Aug 15, 2012 7:58 pm
mastery51 wrote::sisi: yeah, there's no way to fix that. That I can think of. Unless we remove the pistol from Crosshair or retexture a weapon or tool but there won't be an animation on the pistol. Plus, I don't really know how to retexture weapons :dunno:.
NP! this is the BEST CROSSHAIR EVA!!! can it be in my name (if i gave you the idea of the captain rex)
PostWed Aug 15, 2012 8:00 pm
Sure.
Arslan
mastery51 wrote:Sure.
YAY!
I will make it my avatar!!!
Arslan
PostWed Aug 15, 2012 8:03 pm
how do i upload this as my avatar? SINGLE with a white background?
PostWed Aug 15, 2012 8:19 pm
The image needs the same background gray as the forum. This image might be too big I'm not sure though I'm away from my computer to check, I'm on my iPad right now. If it doesn't work I'll shrink it down when I get back to my computer.
You have to go to ( user control panel > profile > edit avatar.)
Image.
Arslan
PostWed Aug 15, 2012 8:40 pm
mastery51 wrote:The image needs the same background gray as the forum. This image might be too big I'm not sure though I'm away from my computer to check, I'm on my iPad right now. If it doesn't work I'll shrink it down when I get back to my computer.
Image.
it is more than 0-6KB that is the message i got! and another thing! i downloaded this map Rich Man;s World THX TO KK! there is longswords (LEGENDARY) i equip em and they are INVISIBLE LOLOLOL! so it is better for this crosshair! Invisible sword=the crosshair looks like shooting!
Arslan
PostThu Aug 16, 2012 9:46 am
dude after a little investigation on the crosshair the antenna isnt on the body it is on the helmet. np if i edit it?
Tots
PostThu Aug 16, 2012 1:47 pm
Arslan wrote:dude after a little investigation on the crosshair the antenna isnt on the body it is on the helmet. np if i edit it?
It is suppose to have the rang finder (the antenna) on the helmet.
Proof
http://www.hasbro.com/corporate/media/press-releases/images/Star-Wars-Captain-Rex-Elect_1.jpg
But I did find something
The visor thing needs the ^ part
So it looks like, but together
T
GC- Tots_32
PostThu Aug 16, 2012 3:51 pm
Yeah, the current version of the Crosshair is a little more simplified, just because the Crosshair ends up being small in the end so details tend to get lost, I feel. But here is a version with the v shape and blue markings. ;)
Return to Crosshairs
