Straight arrow trajectory
LazerLatte
PostTue Jun 18, 2013 12:22 am
With the hacked files error disabler around, modding encompasses much more than just graphical stuff. Real quick here, I'd like to request a simple hack-based mod. Can someone make me a mod for making arrows fly straight without being affected by gravity? (Which gives all bows infinite range but I could care less :P)
Re: Straight arrow trajectory
PostTue Jun 18, 2013 12:27 am
Well, these sorts of things are quite a bit hard to do... We can mod the .json files, but as far as I am aware, arrows "inverted mass" are not in there.. But I'll check again..
PostTue Jun 18, 2013 1:04 am
Okay, so I just went and checked.
So a little brief infomation:
JJ v1.2.4 doesn't have .jsons instead, it has .dat files, which are quite a bit harder to dycrypt and modify (This was Pixbit's way of stopping us modding with the "Disable Hacked Files error" So the last version of Junk Jack with the .jsons was v1.1.
The problem of your request is not that it would be hard to modify arrows in v1.1, It's that Bows wern't even implemented.. So you have a request that is almost impossible.. So yeah.. Erm, Sorry 'bout that.
LazerLatte
PostTue Jun 18, 2013 2:08 am
So the hacked files error disabler simply won't work? Darn...
PostTue Jun 18, 2013 2:17 am
Well, if anybody wants to modify the code with the "Disabled Hacked Files" then they could add a bow, and arrows. Else we have to wait for someone to dycrypt the .dat files.
Return to Requests
