Question for the end of exploration
TheDraiike
PostSat Jun 29, 2013 9:03 pm
Hi,
I ve found today about the universe of this game who s not infinity.
So, is it a bug or is it normally ?
Thanks to answers me and if it´s normally, can you change this ?? That
will be so cool.
Thanks, Draiike :approved:
I love junk jack !
Re: Question for the end of exploration
PostSun Jun 30, 2013 3:15 am
No it's not a bug :) . The invisible barriers were placed in the game because there are memory issues with older devices. If they did remove those barriers it would of caused a loss of compatibility for the older devices. To answer your question if they can remove the barriers, is maybe in Junk Jack x :dunno: but it's not confirmed. unfortunately though, it won't happen in Junk Jack 1 because it can't be updated any further without losing compatibility with older devices.
TheDraiike
PostSun Jun 30, 2013 2:17 pm
okay, so if we wouldn't update junk jack we wouldn't have multiplayer or créative mod ?
And how junk jack x will be support by old device with multiplayer ect... if junk jack can't ?
Can you answers me again ? :|
thanks, Draiike
I love junk jack !
PostSun Jun 30, 2013 4:36 pm
TheDraiike wrote:okay, so if we wouldn't update junk jack we wouldn't have multiplayer or créative mod ?
Thats correct. Accept junk jack x is not going to be an update for the current junk jack app. Junk Jack x will be a separate app that has to be purchased.
thanks, Draiike
Junk Jack x will not support the older devices such as the 1st and 2nd gen. devices because the app requires too much processing power to run correctly. The older devices would crash constantly and may not even get the app to run.
Junk Jack x will only support these devices:
  • IPod touch: 4,5 and maybe 3.
  • Iphone: 4,4s,5 and maybe 3gs.
  • Ipad: All ipad devices.
TheDraiike
PostSun Jun 30, 2013 5:18 pm
Ok, thx
Have you got a specific date at q3-4 to give us junk jack x
and will it be free this day ?
For junk jack 1, you will can ´t make any thing
even if that´s litle ?
And can we go underground deep or we will be
stop at a moment ?
thx, Draiike :sisi:
I love junk jack !
Penafore
PostSun Jun 30, 2013 6:10 pm
TheDraiike wrote:Have you got a specific date at q3-4 to give us junk jack x
we are not too sure about that yet if you want more info on junk jack x look here -> viewtopic.php?f=7&t=11813
TheDraiike wrote:For junk jack 1, you will can ´t make any thing
not sure what you mean....
hope this helps
Image Image
-------------------------Proud Elf Of Reeb42!-----------------------^^^^^^Click^^^^^^
Return to Other
