Junk Machine
King Soda
Junk Machine
PostSat Dec 15, 2012 10:30 pm
You can't put hammers in the Junk Machine :(
4SlotToaster
Re: Junk Machine
PostSat Dec 15, 2012 10:57 pm
The reason for this is because you need a hammer to break the Junk Machine. Nothing else can.
Therefore, when you hit it, it can't produce materials, as it registers as "must break".
Hope I cleared that up for you. Welcome to the forums! :D
Junk Jack Beta Tester
Junk Jack X Beta Tester
Re: Junk Machine
PostSun Dec 16, 2012 12:48 am
It's the same with shelves and showcases… although you might be able to hex hammers into those.
