Getting kicked of junk jack
<<< T.O.N.I >>>
PostMon Dec 22, 2014 4:55 pm
Hello everyone i know that much of you people by adding new things on junk jack from forum.pixbits.com and you get somekind of virus and doesent let you in the game or you play like two minutes or more and kicks you out well there is a simple trick to fix that if you have a jailbroken iDevice you need to download ifile. After you download i file the first thing you going to do is:
1.enter iFile
2.go to var/mobile/applications/find the junk jack folder/go to documents
3.you will se many world1 2 or 3 than press edit chek all the files you want to copy and then press copy that is located down on the screen
4.exit the documents and junk jack folder
5.you can put them in a another folder or just create a new one and press edit paste
6.and than simply delete junk jack and reinstall it
7.after reinstalling you will get a new junk jack folder in ifile copy the files you added to another folder and go to the new junk jack folder and go to documents and simply paste all the files you copied
8.thats it
Rock on fans :rock:
my hero's on this forum-----> multipackwolf...twelvefot...2539Woo,stuart98 and of course pixbits...
Users browsing this forum: Bing [Bot] and 1 guest
