Crashes on start, iPhone 3g
gadasiu
PostSat Jul 21, 2012 10:31 pm
Hello, also - first post, yay :D
I have a problem, with which either a redownload, or a restart doesn't help.
The game restarts after ~10 seconds after running.
All other games I have installed are working for me, and I have no idea what might cause the crashing.
I googled a little, and it looks like there were some problems earlier, but were solved by now. Am I the only one?
Bacibelly
Re: Crashes on start, iPhone 3g
PostSat Jul 21, 2012 11:15 pm
I have a 3GS and I play fine. Are you jail broken?
SCHOOL NO what now...
STOP.
What?
HAMMERTIME
awsomeaustin13
PostSat Jul 21, 2012 11:17 pm
Oh yes. This has happened a lot for me. I either restart my iPod, or tap repeatedly on the loading screen.
oxxxxx[=========~ AWSOMEAUSTIN13 ~=========]xxxxxo
JUNK JACK IS AWESOME
GameCenter=DrLambChops
gadasiu
PostSat Jul 21, 2012 11:19 pm
Yes, I do have Jailbreak since the device is from USA and it's locked for AT&T, while I live in Europe - had to Jailbreak so I can use the phone at all.
doom64
PostSun Jul 22, 2012 12:13 am
I think pixbits said its not the games fault
Its the jailbreaks fault which brings up crashes in the game.
Check out my wallpapers. viewtopic.php?f=6&t=10991
My texture pack. viewtopic.php?f=21&t=12445
gadasiu
PostSun Jul 22, 2012 12:24 am
Tapping the screen didn't help me at all. :/
But why the Jailbreak would make the game crash? I just don't get it, I've never had such a weird problem - the game clearly tries to load (doesn't crash instantly), but after some time (10-15 sec), it crashes. :/
It's really strange if you ask me. I just removed Gamecenter, I'll try reinstalling it again tomorrow - maybe now it will work.
bparker
PostSun Jul 22, 2012 1:12 am
Founder of the GHS (Good Heroes Society)
Ready for JJX
TouchArcade Username: Bparker
My Blog: http://indiegamecentral.wordpress.com
If you have questions about the game PM me. :)
MinerJack
PostSun Jul 22, 2012 2:16 am
Maybe unjailbreak, get started, then jailbreak? Idk.
CRACKY IS WACKY!
RobinRe123
PostSun Jul 22, 2012 8:14 am
Well, I had this problems too. Then I removed the jailbreak and everything works fine.
If you need help, you can send me a PM. I will do my best to answer your questions :)
gadasiu
PostSun Jul 22, 2012 2:34 pm
Removing Game Center didn't help me at all. :/
And I wish I could remove the jailbreak - but as I said, my device is locked for AT&T. Without JB I wouldn't be able to use it.
Does anyone have Jailbroken device with JJ working? We could try to find out which tweak crashes the game.
MinerJack
PostSun Jul 22, 2012 2:35 pm
Yes, plenty of people have it jailbroken. Is it possible to remove the jailbreak then install it again after JJ starts working?
CRACKY IS WACKY!
gadasiu
PostSun Jul 22, 2012 2:50 pm
I have no idea how to remove the JB though. :/
I'm gonna try removing each and every tweak, one after one - until I'll have it working.
-EDIT-
After removing 90% of my tweaks/apps from Cydia:
Ultrasn0w
FakeClockUp
NoSpot
FakeCarrier
iFile
gpsphone
Safari Download Manager
WeBe++
OpenSSH
SBSettings
Activator
MobileTerminal
...still no luck.
It still crashes after 10-15 seconds after launching. *sigh*
MinerJack
PostMon Jul 23, 2012 3:59 am
Did you get it off jns******s?
CRACKY IS WACKY!
gadasiu
PostMon Jul 23, 2012 7:09 am
jnswhat? Censore killed your post. xD
SamF1sh
PostMon Jul 23, 2012 7:23 am
Jailbreak can cause problems, but is probably worth it.
Sam and Ariana 5evr <3
