Floating Jack???
FireHawk707
Floating Jack???
PostSat Jul 28, 2012 3:08 am
I was in the progress of taking down my farm with some TNT when this happened...
So the way it happened was I placed TNT on the floor under me and I lit it up. I took some damage from the explosion and I fell down to the next floor and jack was floating :sisi:
RobinRe123
Re: Floating Jack???
PostSat Jul 28, 2012 3:14 am
Its a known bug as far as I know.
If you need help, you can send me a PM. I will do my best to answer your questions :)
FireHawk707
PostSat Jul 28, 2012 3:16 am
Oh thanks i didnt know if it was known or not so I just had to post it
4SlotToaster
PostSun Jul 29, 2012 11:14 pm
Yes this is indeed a known bug, thanks for reporting anyways! :)
Junk Jack Beta Tester
Junk Jack X Beta Tester
