Drag n Drop
FireHawk707
Drag n Drop
PostThu Aug 09, 2012 2:58 am
when you are on a ladder and you throw out something from your inventory using drag n drop the item will be floating off the ground :sisi:
4SlotToaster
Drag n Drop
PostThu Aug 09, 2012 3:53 am
I just noticed this as well. :sisi:
Junk Jack Beta Tester
Junk Jack X Beta Tester
RobinRe123
Re: Drag n Drop
PostThu Aug 09, 2012 6:11 am
Well, this is just a minor bug, you can still collect the item :). But thanks for reporting it.
If you need help, you can send me a PM. I will do my best to answer your questions :)
FireHawk707
Re: Drag n Drop
PostThu Aug 09, 2012 6:22 am
RobinRe123 wrote:Well, this is just a minor bug, you can still collect the item :). But thanks for reporting it.
No problem :approved:
