Gem block craft is wrong
PSN-Rasta_dezz
PostSun Aug 12, 2012 6:07 pm
It shows the craft with uncut gems instead of cut, too lazy to post a pic :)
Junk Jack dos o Junk Jack equis? Por que no las dos? Junk jack dos equis!! :D
Chris
Re: Gem block craft is wrong
PostSun Aug 12, 2012 6:09 pm
You're supposed to use Uncut. Right?
FOLLOW & CONTACT ME ON TWITTER
1,400+ days on the forum, and with Junk Jack coming to PC I'll be on almost every day now!
AGE POLL
PIE
PostSun Aug 12, 2012 6:15 pm
Right, it shows uncut and you use uncut.
My only issue is that it still uses a forge, when the gem cutters bench seems like a more appropriate addon (it's used for dark stone blocks).
PSN-Rasta_dezz
PostSun Aug 12, 2012 6:57 pm
I was thinking that it it didn't make sense. 4 uncut gems= 1 cut gem & 4 uncut gems = 1 gem block??? That's like 1+1=2 & 1+1=4, the size:usage ratio doesn't add up. Gem blocks should stool use 4 cut gems, and give 16 uncut gems back. Sound right?
PostSun Aug 12, 2012 8:37 pm
Yeah, I see what you mean now.
PSN-Rasta_dezz
PostMon Aug 13, 2012 11:21 pm
So should this be changed or is there a purpose for it?
