Crash? 2g iPod touch
kkrocks1734
  • Location: Tetris House in World 2 and page 82 on registered users!
PostWed Aug 15, 2012 5:27 am
Ok so I just got back from vacation, deleted the beta, and got the update. (it was only on laptop iTunes not iPod app store) and I click on junk jack, and it crashes right away! Help me please :(
Junk. Jack. Is. The. Best. Game. Ever.
As you can imagine, managing a world full of rules and dynamic entities (debris, treasures, mobs), is not like managing some birds thrown with a sling. -Jack
RobinRe123
Re: Crash? 2g iPod touch
PostWed Aug 15, 2012 9:12 am
Do you have 1.2.1 or 1.2? In 1.2.1 it shouldnt crash...
If you need help, you can send me a PM. I will do my best to answer your questions :)
kkrocks1734
PostWed Aug 15, 2012 3:40 pm
I don't know... I just downloaded the update off my computer when I came back.
RobinRe123
PostWed Aug 15, 2012 3:44 pm
Maybe Jack and XsX can help you :)
kkrocks1734
PostWed Aug 15, 2012 3:50 pm
Would this be one of those situations where I would need 1.2 first for 1.2.1 to work?
RobinRe123
PostWed Aug 15, 2012 3:55 pm
kkrocks1734 wrote:Would this be one of those situations where I would need 1.2 first for 1.2.1 to work?
Yes, that should be the problem. If you skip versions, the worlds are not compatible anymore. You will have to delete all your worlds and create new ones.
4SlotToaster
PostWed Aug 15, 2012 9:11 pm
No that should not be the case. I skipped updates perfectly fine. I am also on a 2nd Gen.. :sisi:
Junk Jack Beta Tester
Junk Jack X Beta Tester
bparker
PostWed Aug 15, 2012 9:18 pm
XsX stated that skipping from 1.1 to 1.2.1 would not cause the worlds to corrupt. Make sure to check you have 1.2.1 because Chris had a similar problem but then realized he was on 1.2 and just needed to down load another update.
Founder of the GHS (Good Heroes Society)
Ready for JJX
TouchArcade Username: Bparker
My Blog: http://indiegamecentral.wordpress.com
If you have questions about the game PM me. :)
PostThu Aug 16, 2012 1:22 am
It says the version number at the bottom of the main menu.
PostThu Aug 16, 2012 1:36 am
You're missing what she's saying. It crashes when launching the app, not when loading a world or anything.
kkrocks1734
PostThu Aug 16, 2012 1:48 am
Correct. Right as I open the app about a second later it crashes.
4SlotToaster
PostThu Aug 16, 2012 2:20 am
Stuart98 wrote:You're missing what he's saying. It crashes when launching the app, not when loading a world or anything.
she's* :sisi:
PostThu Aug 16, 2012 2:21 am
Fixed.
Molotov13
PostThu Aug 16, 2012 3:16 am
SHE? I didn't know, I had the same problem with my 2nd gen so I deleted it and redownloaded it off the app store
[GC: SladeMolotov13]
bparker
PostThu Aug 16, 2012 11:19 am
did that fix the problem?
Ready for JJX
