World just got smaller??
WleoW
PostWed Aug 15, 2012 2:49 pm
Well i´ve mined an entire wolrd, from the left to the right, complete;
but then i want to go back to the other side and its if the world "compacted itself"
i cant go where i was before, and i have evidence of it!!
kando
Re: World just got smaller??
PostWed Aug 15, 2012 6:33 pm
Somehow you may have crossed the barrier on the left or the right...basically this is how it works...
theres 768 blocks across the world. Once you reach the first 5-10 blocks and the last 5-10 blocks, one way of walking becomes disabled and you walk into an invisible wall. If you walk the complete opposite way as far as you can go, you are almost on the border between the 2 sides.
If you place a bed in there and another bed on each outside, you can set your spawn, die, and spawn inside of the barrier...might give you a better idea of what you're up against.
Either way, upload your world?
kando wontu
World Hacker/Hexer & Wiki Admin/Contributor
Light World Mods: http://tinyurl.com/9zxxfvs - http://tinyurl.com/96ymxkb
63 Hearts Mod: http://tinyurl.com/9avfkjt
"UNOFFICIAL" Chat: http://tinyurl.com/9lmexcn
PostThu Aug 16, 2012 1:21 am
Exit the app then come back, that should fix it.
WleoW
PostFri Aug 17, 2012 8:12 pm
PostSat Aug 18, 2012 2:22 am
Are you sure that you actually walked over there before? Because the torch is only 3 blocks away, so you could have reached over with mithril tools then placed a torch at the edge of the screen.
How many blocks are there that you can't walk on?
SamF1sh
PostSat Aug 18, 2012 2:26 am
In the video he zooms out and you see evidence of him being past the world barrier.
Sam and Ariana 5evr <3
PostSat Aug 18, 2012 2:50 am
I see no such evidence. The lit up stuff on the left side of the screen is the complete opposite side of the world. He has to walk all the way to the right to get to that.
4SlotToaster
PostSat Aug 18, 2012 12:40 pm
I honestly am not seeing the bug here.. :sisi:
Junk Jack Beta Tester
Junk Jack X Beta Tester
WleoW
PostSat Aug 18, 2012 4:11 pm
So every world in junk jack is circle like??
thn that kinda explains it!
PostSun Aug 19, 2012 2:29 pm
Yes, the worlds loop around. You just can't walk all the way around.
