Infinite consumables glitch
LazerLatte
PostThu Nov 01, 2012 12:19 am
If you tap and hold a consumable in your inventory then drag your finger away before releasing it, you use the consumable but, well, it doesn't get consumed.
Re: Infinite consumables glitch
PostThu Nov 01, 2012 12:36 am
When I do that nothing happens.
I mean I hold on it until the green box appears, then move my finger away. My health doesn't go up, the item doesn't go down.
LazerLatte
PostThu Nov 01, 2012 2:04 am
Odd... How far are you dragging? It only worked for me when I dragged clear across the screen.
PostThu Nov 01, 2012 2:13 am
Do either of you have tap to move on?
PostThu Nov 01, 2012 2:20 am
I do not have tap to move on.
LazerLatte
PostThu Nov 01, 2012 5:13 pm
No, I don't have tap to move on. But I tried it again and it didn't work. So many freak glitches....
PostThu Nov 01, 2012 10:44 pm
Guess it WAS a glitch, and not a bug. Glitches are a lot harder to kill, but also a lot less likely to occur.
PostFri Nov 02, 2012 2:03 am
Just like random crashes... Most were fixed with the new engine awhile ago, but there are those random crashes (most likely due to RAM) that currupt your world...
Users browsing this forum: Bing [Bot] and 1 guest
