Stuck.
Johnbarkee
Stuck.
PostMon Nov 19, 2012 4:21 am
Sometimes I wake up and I can only move in the block I am in. (Where my bed is.)
Dbush
Re: Stuck.
PostMon Nov 19, 2012 5:04 am
That rarely happens. Just restart the app. That should fix the issue.
Johnbarkee
Re: Stuck.
PostSun Nov 25, 2012 4:59 am
Tried that. Doesn't work. Good idea.
Chris
Re: Stuck.
PostSun Nov 25, 2012 5:03 am
Did you do the thing where you tap the bed, the screen starts to darken, the you pull down the iPod's notifications pull-down tab from the top, then pull it back up?
Cause if you did, and you're getting stuck in the one block, then that is most likely the culprit.
No I didn't visit in 2021, why do you ask?
Also yes, you're all blocked on Twitter ¯\_(ツ)_/¯
