Strongest ore?
silverseagull
Strongest ore?
PostSun Sep 01, 2013 4:40 pm
Which is the strongest ore in JJx?
Copper = Iron
Silver stronger, than copper/iron
Gold stronger, than silver
Mithril stronger, than gold
Antanium stronger, than mithril
Titanuim stronger, than antanium
Is that correct?
Chris
Re: Strongest ore?
PostSun Sep 01, 2013 4:44 pm
Yeah, something like that.
Wood<Stone<Copper<Silver<Gold<Mithril<Antanium<Titanium
(don't know if Tin or Bronze fit in there somewhere)
Though, Antanium mines faster than Mithril, but Mithril lasts longer.
Not sure about Titanium.
In the coming weeks, the "JJX Wiki" will be up and running and will contain more accurate info like this.
FOLLOW & CONTACT ME ON TWITTER
1,400+ days on the forum, and with Junk Jack coming to PC I'll be on almost every day now!
AGE POLL
PIE
BluesClues
Re: Strongest ore?
PostSun Sep 01, 2013 5:27 pm
It depends what you mean by strongest. For example mithril has more durability than antanium but antanium break blocks and kills mobs faster.
Copper and iron aren't equal by the way, iron is stronger
Avatar created by mastery51
Re: Strongest ore?
PostSun Sep 01, 2013 5:30 pm
Mithril has the most durability, but titanium is the most powerful.
silverseagull
Re: Strongest ore?
PostSun Sep 01, 2013 5:51 pm
Thanks everyone for your replies.
I was thinking about making armor, from which ore it will be better.
Re: Strongest ore?
PostSun Sep 01, 2013 6:01 pm
Armor lasts forever, so, for a normal ore, titanium is best.
