Electronics: 2-way light switch or door control
PostThu Nov 24, 2016 6:41 pm
I made this 2-way light switch, just sharing it with anyone wanting to use it.
You can toggle either of the switches and it will toggle the state of the output (in this case a light). You could also use it to open/close a door.
Let me know if you have any other improvements or suggestions :D
PostThu Nov 24, 2016 7:27 pm
Better example of the 2-way light switch:
PostThu Nov 24, 2016 7:28 pm
Example of the 2-way door switch:
AFanOfStuff
Re: Electronics: 2-way light switch or door control
PostThu Nov 24, 2016 9:39 pm
I love creations like these despite the fact that I have no idea how they work or how to make good things myself.
:yawn:
PostFri Nov 25, 2016 12:57 am
Actually your left branch calculates (A & ~B) so it's true when first is on and second is off, your right branch calculates (~A & B) so it's true when first is off and second is on. The XOR gate which combines them it's true when inputs are different but (A & ~B) and (~A & B) can't never be true or false together, they're mutual conditions.
So (A & ~B) ^ (~A & B) simplifies to (A & ~B) | (~A & B), where ^ is XOR and | is OR. But (A & ~B) | (~A & B) is true when both inputs are in different states, which is the XOR operation, so the layout can be simplified to A ^ B:
You can see the minimal form of your boolean logic here: https://www.wolframalpha.com/input/?i=(A+and+not+B)+xor+(not+A+and+B)
PostFri Nov 25, 2016 5:57 am
Jack wrote:Actually your left branch calculates (A & ~B) so it's true when first is on and second is off, your right branch calculates (~A & B) so it's true when first is off and second is on. The XOR gate which combines them it's true when inputs are different but (A & ~B) and (~A & B) can't never be true or false together, they're mutual conditions.
Haha classic!
I was just thinking how impractical mine is due to the large footprint, and wishing it could simplified. Yours works, thanks! :D
Users browsing this forum: No registered users and 4 guests
