Spring Biome in Terra?
PostWed Dec 21, 2016 12:58 am
I have a recipe for A beehive, which can only be made with honeycomb. I read that they can be found in Spring Biomes on the surface of Terra, but I've never seen one!
Any help on this would be greatly appreciated!
Re: Spring Biome in Terra?
PostWed Dec 21, 2016 3:27 am
To create a season world such as spring go to the create a world menu.
Next, select a standalone Terra world> select customize> in the season menu click until it says spring.When done click the back arrow and then click generate.
Note: You might have to generate a few large spring worlds to get one.
Here's a photo of one in the wild.
PostThu Dec 22, 2016 1:22 am
mastery51 wrote:To create a season world such as spring go to the create a world menu.
OMG ok thanks! So are there different things in all the seasons?
How about underground biomes? Or other planets?
PostThu Dec 22, 2016 3:38 am
Correct, there will be a couple biome resources for each season on the surface. (Trees, beehive, hay bale, plants, etc.)
It only changes the surface. No underground biomes.
The season option only shows up for standalone Terra worlds.
PostTue Dec 27, 2016 5:19 am
mastery51 wrote:Correct, there will be a couple biome resources for each season on the surface. (Trees, beehive, hay bale, plants, etc.)
Thanks, I spent hours creating seasonal worlds and collecting so many new items. I didn't see anything new in "Winter" though, seems the same as when you select "none"?
PostTue Dec 27, 2016 6:54 am
:) Yes it's the same now because of the Christmas update. But when the holiday theme is removed in an update there will be less snow biomes in the none season setting.
