Blocks which won't explode?
PostTue Dec 27, 2016 4:19 pm
I couldn't find this on the wiki.
I saw the explosives page which details the explosive damage, but couldn't find a page which lists the strength of each block, eg Stone Compact.
Does anyone have a list of block strengths? Which is the strongest? I want to stop those Skexotons from blowing up lava!
I was fishing just now, and one blew me up, all my equipment was lost in the lava!
Re: Blocks which won't explode?
PostTue Dec 27, 2016 9:55 pm
Metal blocks (at least the higher levels). And I think boulders are still blast proof?
PostTue Dec 27, 2016 11:40 pm
"Thick stone" is also a good barrier for explosion. But be careful, mobs can spawn on natural stones so if you use this make sure you flooring is a crafted block of some kind. Wood block, brick, etc. You should be safe.
PostWed Dec 28, 2016 2:11 am
mastery51 wrote:"Thick stone" is also a good barrier for explosion. But be careful, mobs can spawn on natural stones so if you use this make sure you flooring is a crafted block of some kind. Wood block, brick, etc. You should be safe.
So I spent hundreds of hours farming dozens of different types of blocks, only to find out that they aren't practical to make a house out of?! Lol
Mobs still won't spawn if the light Level is >= 7, right? Regardless of block type.
PostWed Dec 28, 2016 3:22 am
:sisi: Correct, level 7 lighting will help keep most mobs from spawning. But mobs particularly small slimes or spiders sometimes find a way if the lighting isn't perfectly 7 all the way. Small houses work fine. Large mansions are a little bit harder to light. Mobs might spawn on top of a natural block if not careful. So just putting any crafted block, wood, stone, brick, etc. as a floor would insure you they won't.
LordModz
PostThu Dec 29, 2016 9:00 am
What exactly is a level 7 lighting ? And also would this stop small mobs like snakes,rats and so on from spawning on a underground house ?
GC: LordModz
Steam: LordModz1
Discord: LordModz#3398
KIk: 227WeedRooller420
PostThu Dec 29, 2016 11:15 am
It's just a term I made up. Level 7 lighting = a Lighting level that is at 7.
The light level should not go below 7 or enemy mobs might spawn on top of that block.
A torch ever 4 or 5 blocks should keep most enemy mobs from spawning on natural blocks, basically.
I'm just saying be careful.
LordModz
PostThu Dec 29, 2016 8:21 pm
This seem to work well with enemy mobs, my issue is with underground building with the peaceful mobs like Rats,Snakes,Small spider, etc...
http://imgur.com/UAsoms7
Well the image show the underground room that I'm having the issue with as you can it have a whole bunch of lights and still getting peaceful mobs spawning :/.
GC: LordModz
Steam: LordModz1
PostFri Dec 30, 2016 7:30 am
Yes it would seem that peaceful mobs don't obey the same lighting rules. They are more for decorative purposes.
LordModz
PostSat Dec 31, 2016 1:46 am
desTROYer74 wrote:Yes it would seem that peaceful mobs don't obey the same lighting rules. They are more for decorative purposes.
Well I guess is time to start looking for the lighting rule for peaceful mobs :/..
I don't remember peaceful mobs being this annoying back on 2.4.9.
GC: LordModz
Steam: LordModz1
