Highest luck build?
EventHorizon
Highest luck build?
PostThu Jun 29, 2017 9:57 pm
I have rustallon armor with an tourmaline ring. Is there a build with higher luck out there?
Previously known as: PSN-Rasta_dezz
Steameventhorizon32
Re: Highest luck build?
PostFri Jun 30, 2017 12:09 am
Complete Tor-Uber Mob or Mykon-Umber Mob sets with the the Luck Necklace, all equips encrusted with a tourmaline gem wih a luck potion using bone (Magnificent Potion with 14 power)
*Recipe for luck potion is Bird Beak+Feather+(Reagent: Bone)
*I believe Diamond Ring has better luck with 20 Luck chance instead of the Tourmaline Ring that only has 15
EventHorizon
PostFri Jun 30, 2017 1:37 pm
Diamond ring is 20 luck you're right.
So full tourmaline tor armor plus a tourmaline encrusted diamond ring would yield +110 luck if I'm not mistaken. Wish there was a potion that gives a luck multiplier haha
Steameventhorizon32
