How do you get these awesome light bulbs?
PostSat Aug 05, 2017 6:55 am
I want to be able to dig these up and take them home, how is it possible? There's a few other things that vanished when I dug the block, but can't recall them all.
Ramsey26
Re: How do you get these awesome light bulbs?
PostFri Aug 11, 2017 4:21 am
Those light bulbs definitely awesome. But unfortunately there is no way to retrieve and incorporate them into your house as far as I know. :/ Unless you build a house around it or something..
You can never have too much junk... Just not enough storage... :D
SarahT
PostThu May 10, 2018 9:16 pm
You hit them with your hammer untill it falls off. The thing is, you have to be lucky, sometimes you'll get the bulb after hitting it with the hammer, sometimes not.
