I have been noticing around the Help & Support forums that people heed great help with what gems/items do what. So here is your guide! This long article does not include ALL items, but it does include rare ones. The rest are for you to discover on your own.
How to Encrust
Encrusting is what allows you to upgrade your tools/armor. To encrust, you will need gems. Find them underground.
There are nine gems to be mined underground, they are:
•Ruby
•Emerald
•Topaz
•Sapphire
•Amythest
•Diamond
•Tourmaline
•Citrine
•Tanzanite
Now to use them:
1. Take four of the same gem and craft a Encrust Gem.
You will need the Tinkerer's Tools Add-On.
G-Gem
(_)(G)(_)
(G)(_)(G)
(_)(G)(_)
2. Once crafted the gem, press and hold the the crafted gem in your inventory.
3. Choose an item to encrust!
Encrusting Armor
Ruby: 25% Immune to lava damage.
Emerald: 25% Immune to acid damage.
Topaz: 25% extended breathing underwater.
Sapphire: Glow in the dark.
Amythest: Small attack increase.
Diamond: Small defense increase.
Tanzanite: 25% to the speed stat.
Citrine: + 0.5 hearts
Tourmaline: Luckier, but decreases defense.
Encrusting Tools
Ruby: Increases range.
Emerald: Destroys adjacent blocks and increases knockback.
Topaz: Increases durability.
Sapphire: Glows in the dark.
Amythest: Increases power.
Diamond: Chance for double drops.
Essence Baubles
E= Essence
B= Gold Bar
(B)(_)(B)
(_)(E)(_)
(E)(_)(E)
Water: Breathe underwater.
Acid: Immune to acid damage.
Air: Immune to fall damage and increases speed.
Arcane: Adds two hearts.
Evil: Increase attack/defense.
Stone: Increase in defence.
Ethereal: Magic attack increase.
Sand: Immune to blast damage.
Gold Rings
G=Gem
B=Gold Bar
(B)(_)(B)
(_)(G)(_)
(G)(_)(G)
Ruby: Immune to lava damage.
Emerald: Immune to acid damage.
Topaz: Breathe underwater.
Diamond: Increase in defense.
Amythest: Increase in attack.
---immunity by 25%
Planets
Here is a picture of all the planets and what portals you can find on each of them.
Ores
Copper: Found on Terra, Seth, Alba, Yuca, Xeno, and Magmar.
Iron: Found on Terra, Seth, Alba, Yuca, Xeno, and Magmar.
Silver: Found on Terra, Seth, Alba, Yuca, Xeno, and Magmar.
Gold: Found on Terra, Seth, Alba, Yuca, Xeno, and Magmar.
Mithril: Found on Seth, Alba, Yuca, Xeno, and Magmar.
Antanium: Found on Alba, Yuca, Xeno, and Magmar.
Galvanium: Found on Cyro.
Titanium: Found on Alba, Yuca, Xeno, Cryo, and Magmar.
Tools
Wood: 16 Durability, 1 Power, 1 Range
Stone: 32 Durability, 1.2 Power, 1 Range
Copper: 64 Durability, 1.3 Power, 2 Range
Iron: 128 Durability, 1.5 Power, 2 Range
Silver: 196 Durability, 1.7 Power, 2 Range
Gold: 128 Durability, 1.9 Power, 3 Range
Mithril: 384 Durability, 2 Power, 3 Range
Antanium: 512 Durability, 2.5 Power, 3 Range
Galvanium: 1024 Durability, 2.7 Power, 3 Range
Titanium: 512 Durability, 3 Power, 4 Range
Survival Guide
----Basics-
Before building an amazing house with decorations and everything, you must first learn how to survive. When you first spawn in a world, your first priority is to find trees. I recommend crafting a wood axe after the first few so you can chop chop faster. Another main thing is to dig up coal from the dirt blocks below. Don't confuse coal with tin, as tin has a silver glint to it. Coal can be used to craft torches, and smelt items in a furnace. There will most likely be animals all around you, so make sure you slaughter some cows, sheep, pigs, and chickens! Their meat will be quite helpful--and tasty!
----Night-
Night is approaching! It is time to build your first shelter! I recommend crafting torches, shovels, swords, and a workbench. First, with your shovel, you dig into the ground as your first cave. Make it spacial, so you can improve it later! With your torches, light up your cozy cave so monsters don't spawn inside. Place a workbench, as they are helpful for other add-ons, such as furnaces, mason benches, and even wood armor!
----Mining-
Mining is one of Junk Jack's best features, as the game pretty much revolves around it! With your shovel, in your newly dug cave, start digging downwards in a chosen fashion, and begin your adventure. There WILL be monsters down here, so make sure you have your swords equipped. Soon enough, you will begin to see more coal, tin, and even stone! Craft some pickaxes, and break away that rock. Under the stone level, more caves will form, with interesting biomes and ores! Biomes include chests in them, which are helpful in the state of collecting rare items, weapons, and tools! But remember--you will need a hammer and a key to break most chests!
----Monsters-
Monsters, or mobs, play a big role in Junk Jack X, as they make a challenge of the game. They spawn in dark areas, mostly at nighttime, and will attack you without hesitation! Most monsters can be defeated with a sword, but there are also spears, and mauls! Mauls are used against skeletons, and mostly every scary mob that shakes and rattles. Spears, as assumed, are best used against peaceful mobs, such as cows, pigs, chickens, and sheep!
Other Important Tidbits/Guides:
Here I will post other guides created by myself, and others. If you want to suggest one, leave the link in the replies. If I find it important, I'll add it. When viewing another guide, please post your thoughts on that one instead of this one. We don't want to get confused.
How To - Restore Backup Files ! -by Sollision
Numbers for JJx - by 123outerme
CraftBook Tutorial - by SmexyJunkie
The post doesn't merge correctly into here, so just tap the link to continue. This includes the entire tutorial for Junk Jack!
When, Where, How - Forum Guide - by SollyStartles
The post doesn't merge correctly into here, so just tap the link to continue...and because it's super long.
Building Guide - by Wolfe
Click the link above. This post is ridiculously long, but is still just amazing.
Any suggestions or things you want me to add? Leave a reply below! I will be sure to add them to the list. I will add whatever you need, so just speak up! Armor, weapons, you name it.
Hope this helps you!
How to Encrust
•Ruby
•Emerald
•Topaz
•Sapphire
•Amythest
•Diamond
•Tourmaline
•Citrine
•Tanzanite
Now to use them:
G-Gem
(_)(G)(_)
(G)(_)(G)
(_)(G)(_)
Encrusting Armor
Encrusting Tools
Essence Baubles
E= Essence
B= Gold Bar
(B)(_)(B)
(_)(E)(_)
(E)(_)(E)
Gold Rings
G=Gem
B=Gold Bar
(B)(_)(B)
(_)(G)(_)
(G)(_)(G)
---immunity by 25%
Planets
Ores
Tools
Survival Guide
----Basics-
----Night-
----Mining-
----Monsters-
- Open Spoiler
- I see a lot of you are struggling in restoring your .bak files for Junk Jack X. Don't know what I'm talking about?
A .bak file is the leftover file when you delete a world. The original world file will be deleted, but your backup file will still exist.
Okay, let's get started, shall we?
Requirements:
a: PC or Jailbroken iOS Device
b: Good listening skills.
c: A brain.
PC Use
1) First of all, you are going to want to have a file viewer for your PC. WinRar for example.
2) Download iFunBox and find Junk Jack X inside the PC application. (Your idevice must be connected to view its files).
a: Applications > Junk Jack X > Documents > Worlds
b: You will see a backup file of your recently deleted world, but not the original world file.
c: Backup file will be named - name.dat.bak . "Name" is whatever you have named your deleted world.
3) Copy the .bak file and paste it into a folder wherever you want. (Desktop folder is recommended.)
4) Use WinRar to find the .bak file in your desktop folder, or wherever you pasted it.
5) Find the file, and rename it to name.dat instead of name.dat.bak .
a: Make sure the original .bak file is backupped (oh, the irony) so it is able to try again.
6) Paste the new renamed file into your Junk Jack X world folder back in iFunBox.
a: And delete the old one.
b: If it works, you can delete the file on your desktop also.
iOS Use
1) Follow these steps if your iOS device is jailbroken.
2) Download iFile and find Junk Jack X inside the Cydia application.
3) Copy the .bak file and paste it into a folder wherever you want. (New or Documents Folder is recommended).
4) Find the file, and rename it to name.dat instead of name.dat.bak .
b: If it works, you can delete the file in the other folder you made also.
Side Notes:
This method will only work if your .bak file has bytes. This is where brain is needed.
This currently only works for standalone worlds. I will try and experiment for adventure worlds.
Whew. Hope this helps.
- Open Spoiler
- I decided to create a list of tedious-to-calculate items. These items will be useful in some way, whether to calculate how many items you need for a certain craft, or otherwise. I will start out with the easy ones.
*Stack (999) of Metal Blocks: 999 * 4 ingots or 3,996 ingots
*Stack of Nails: 499.5 or 500 (with one left over) Iron, or 124.875/124 Iron Blocks with 3 ingots left over
*Full Metal Armor: 16 ingots and 7 bars or 22 ingots with 2 bars left over
*Stack of Wood Planks: 499.5 or 500 (with one left over) Wood
*Stack of Torches: 499.5 or 500 (with one left over) Coal and Planks, or 499.5/500 (with one left over) Coal and 249.25/250 (with one left over) Wood
*999 Iron (Nails): 999 * 9 Nails or 8991 Nails
*999 Iron Blocks (Nails): 999 * 36 Nails, or 35,964 Nails
999 Gem Rings (Uncut Gems): 999 * 4 Uncut Gems or 3,996 Uncut Gems and 999 * 2 Gold bars or 1998 Gold Bars, or 999 Gold Ingots.
*999 Buckets: 999 * 5 Wood Planks/Iron Ingots or 4,995 Planks/Iron
Full Damage Type Weapon Set (Blunt, Slash, Pierce, Magic): 5 Galvanium and 7 Iron Bars
Full Weapon Arsenal (Bow, Sword, Spear, Maul): 8 Planks
2 Spider Silk, 4 Metal Bars, 5 Metal Ingots > Iron, 7 Iron Bars, 2 Ingots >= Iron, 2 Stone/Wood
Let me know if I made any calculation errors, or if I just derped in general. If you want me to add something, feel free to request it!
Edits:
1: Added extra info
2-4, 6-7: Added new numbers
5: Fixed some errors
Last edited by SollyStartles on Sun May 01, 2016 7:08 pm, edited 57 times in total.
