(¯`·._.·[ "Craftbook + Tutorial" ]·._.·´¯)​
SmexyJunkie
PostSat Dec 28, 2013 10:45 pm
I've been seeing a lot of Posts lately asking how to craft things like Beds, furniture, etc. Therefore, I decided to make a Crafting Manual, so I don't have to create the entire manual as a reply to a post. Here it is:
Tutorial: wrote:
Basics wrote:
Welcome To Junk Jack X
Dig blocks, search for treasures, build your humble shelter or a huge castle, figth monsters and find portals that leads to new worlds!
This guide will teach you the basics of the game.
Destroying Blocks
Almost everything can be destroyed by tapping on it. Tap some trees and start gathering wood, useful to crafting basic items.
Gathering Resources
Blocks drop useful resources, needed by many craft recipes.
In the world you will find crates and chests. They can contain treasures, weapons, and much more!
Inventory wrote:
Managing Inventory
Managing inventory is simple. Follow these simple steps to get the best of it.
Moving Items
1. To move and item, just drag it.
2. If you don't like dragging, enable the "tap to move" option.
Consuming Items
1. Hold a finger on a useable item, like fruits or craft notes, to consume it.
2. If the item is in a quickslot, you can even tap to consume it.
Managing ITems
1. Tap a selected item to split it in two even piles.
2. Hold your finger on an item to combine all the similar items around it in the same slot
Magnifying Glass
1. Tap the magnifying glass to keep item names shown for the selected item.
Trashing Items
1. Tap the trash to enable item trashing. Select the items you want to trash and confirm by tapping the trash button. Delete a single item by dragging it on the trash.
Item Categories
1. Each item has its category shown by a colored border in the inventory. This option is disabled by default and can be enabled through the "Item Outlines" option.
Throw Items
1. To throw an item away, drag it out of the pane. You can also throw items with the inventory closed by holding your finger on the screen where you want to throw it.
Controls wrote:
Moving Around
1. Moving your character is easy. Just slide your finger in the direction you want to move.
Jumping
1. When you are near the edge of a block you can do a dash jump by swiping diagonally, up or down.
Breaking Blocks
1. Tap block repeatedly to break them.
2. Enable the "Hold To Break" option in the main menu to break blocks by holding your finger on them.
Climb Ladders
1. To climb ladders, just swipe up or down.
2. You can dash jump from ladder edges
Swimming
1. Swimming is allowed in block full of liquid. To swim, swipe in the desired direction. Keep breath under control and remember that some liquids hurt you!
Tools wrote:
Tool Types
Each tool has its own useful task:
> Shovels, useful to dig dirt.
> Pickaxes, needed to destroy rocks.
> Axes, to chop trees faster.
> Work Hammers, used to reak furniture, chests, and useable items.
Hoes, used for tilling soil when farming.
Better Tools
Tools made of metal require an anvil addon to be crafted. They break blocks faster, and are more durable depending on the metal quality.
Interface wrote:
Inventory
1. The inventory contains your backpack, the crafting table - addons, and the equip pane.
Craftbook
1. The craftbook contains all available crafts and this guide.
2. If simple crafting is enabled the craftbook is also used to craft items.
Map
1. The map shows an overview of the world.
2.You can zoom the map further back by holding your finger on the screen when it is opened.
Quickslots
1. You have some slots to the right of the screen. These are called "quickslots" and are used to hold items and have quick access to them. Just tap a quickslot to select it.
Chat
1. The chat button is only available in multiplayer. Use it to chat with other people!
Addons wrote:
Crafting with the addons
1. Most crafts require an addon to be crafted. Stand in front of the needed addon, then tap it, or open the inventory. The craft grid will be correctly themed according to the addon you are using.
Crafting wrote:
How to craft
1. Craft by dragging thee required items inside the crafting grid.
2. More complex items require an addon to be crafted.
Finding New Crafts
1. During your adventure you will find craft notes that contain new recipes, useful for your adventure.
2. To add a note to the craftbook, hold your finger on it.
Simple Crafting
1. Enable simple crafting in the options to craft objects from the craftbook.
2. This way of crafting requires time according to the craft difficulty. Queue crafts by tapping more times.
Weapons wrote:
Weapon Types
1. Weapons are used to figth monsters. There are many different weapons, each one with a particular type of damage. Blunt, Slash, Pierce, Magic.
Monster Defences
1. Every monster can have weak or strong defences against specific damage types. Try to find the most effective weapon to kill them!
Better Weapons
1. Weapons crafted wwith better materials yield more damage, and have longer attack range.
2. Remember that you need to have clear path to a mob to attack it.
Ranged Weapons
1. Use ranged weapons from distance. Tap the sceen to shoot! Some ranged weapons require specific ammo, like the bow.
2. Put ammo in the correct inventory slot before using the weapon.
Equipment wrote:
Equip Slots
1. You can equip 5 different equip pieces: hats/helmets, chests, legs, feet and trinkets.
2. Tap the equip label on the lower right of the inventory to access your equip slots.
Equip Types
There are many equippable items that you can find and craft. Some are just fancy items while other give you benefits.
Equip Damages
There are 4 types of damages:
>Slash Damage
>Blunt Damage
>Pierce Damage
>Magic Damage
Every weapon, bullet and mob has one specific type.
Equip Defences
There are 4 types of defences:
>Slash Defence
>Blunt Defence
>Pierce Defence
>Magic Defence
Every armor, trinket and mob has different values for each type.
Equip Resistances
There are 5 types of resistances:
>Lava Resistance
>Acid Resistance
>Breath Resistance
>Explosion Resistance
>Fall Damage Resistance
Every armor and trinket has different values for each type
Equip Movements
There are 4 types of movement bonuses:
>Walk Speed
>Climb Speed
>Dash Speed
>Swim Speed
Every armor and trinket has different values for each type.
Equip Bonuses
Equip pieces can have different bonuses:
>Attack bonuses increase damage
>Defence bonuses reduce damage from mobs and bullets
>Resistances reduce damage from special types of damage (Up to 100% immunity)
>Movement bonuses which increase movement speed
Special Bonuses
There are many other stats:
>Health (And healing) bonus
>Luck
>Spike damage
>Hidden bonuses!
Containers wrote:
Organize Your Stuff
1. Chests help you store items gathered in your adventures.
2. Metal Chests hold more objects. Stack chests and addons by placing them on top of each other.
Survive wrote:
Survive In A Hostile World
When night comes, monsters will spawn. Build a shelter to protect yourself! Gathern coal from dirt, use it with wood planks to craft some torches.
Remember: most monsters won't spawn in well-lit areas!
Farming wrote:
Grow Plants
1. Grow wheat, fruit trees and many other types o plants!
2. Eventually, fruits will grow on plants, tap them with bare hands to make them fall. Seeds can be found in crates underground.
Tilling Ground And Supports
1. some plants require tilled soil, that must be prepared with a hoe, while others require specific supports.
Sleeping wrote:
Home Sweet Home
1. Tap a bed to use it as a new spawn point. If you die, you will respawn there. Tap the bed at night to sleep, this makes you skip the night and restored your health.
Forge wrote:
How To Use The Forge
1. Use the forge to smelt ingots, craft glass, or cook meat. Place fuel into the right slot and the item you want to smelt or cook in the left slot.
Forge Fuel
1. The forge will automatically work as long as there is fuel and items to consume.
2. There are many fuel types, some are more efficient than others.
Building wrote:
How To Build
1. To build, drag a placeable block or item into a quickslot, select it, and tap where you want it to be placed.
Placing Blocks
1. Back layer is filled before the front one.
2. Place a block on yourself to automatically jump over it!
Placing Doors And Other Items
1. Some items, like doors, require to be attached to the block below, above or behind. If you see a red square you're placing it in the wrong way!
Breeding wrote:
Capture Animals
1. Breeding is used to grow animals in specific stable block.
2. Capture animals with the taming collar. Tap on the animal with the collar selected, and you will capture it in your inventory.
Stable Animals
1. To stable an animal, just place it on the appropriate stable.
2. Each stable can hold up to 3 animals.
Stable Interface
1. Tap a stable to see it's content and the status of the respectie stabled animals.
2. The pane shows stabled animals, their gender and happiness.
Feeding Animals
1. Place food in the stable slot and your animals will use it when they're hungry.
2. Different inds of animals like different kinds of foods.
Love Is In The Air
1. Well fed animals of the same stable will breed a baby if there is room available.
2. Keep animals near their home stable, or they will flee!
Cooking wrote:
Cooking Foods
Cook a variety of food with the cooking pot and cooking ware. Some recipes will need one, or een both of them.
Remember: Cooked food is more effective!
Trades wrote:
Trades
1. To trade with someone tap him while holding a Trading Scale.
2. Tap the items you want to trade.
2. Accept the trade by tapping the button (Cancel the trade by tapping the backpack)
Portal Stones wrote:
Travel To Other Dimensions
1. During your adventure you might find special chests that contain portal pieces.
2. To build a portal you need 3 portal pieces.
Remember: Portal Chests only spawn in adventure worlds.
1. Place three pieces in a pyramid and a portal will appear.
2. Tap the portal to travel to a new planet.
Furniture wrote:
Furniture
1. Place a furniture frame.
2. Place a liner on top of it to combine them.
3. Paint your furniture to make it unique!
Jewelcrafting wrote:
Jewelcrafting
Jewelcrafting allows you to encrust your tools, weapons and armors with gems to imbue them with useful powers.
Jewelcrafting
First, you need to cut a gem with the tinkerer's tools, then consume the gem and choose what to encrust.
Jewelcrafting
The encrusted item will show the gem icon while in the inventory. Available powers are:
> Power, durability or uses enhancements.
> Attack or defense bonuses.
> Side effects, such as double drops.
> Light glows.
> Imunities.
Signs wrote:
Signs
1. Tap a sign to read its contents.
2. To edit a sign, first craft a pencil, then select it and tap the sign to open the edit view.
Crafts wrote:
Addons wrote:
Workbench wrote:
Anvil wrote:
Requires Workbench
Tinkerer's Tools wrote:
Requires Workbench
Woodworker Bench wrote:
Requires Workbench
Carpentry Bench wrote:
Requires Workbench
Mason Bench wrote:
Requires Workbench
Spinning Wheel wrote:
Requires Workbench
Loom wrote:
Requires Workbench
Dying Machine wrote:
Requires Workbench
Tanning Tools wrote:
Requires Workbench
Cooking Ware wrote:
Requires Workbench
Cooking Pot wrote:
Requires Workbench
Forge wrote:
Requires Workbench
Tools wrote:
Wood Axe wrote:
Wood Hammer wrote:
Wood Hoe wrote:
Wood Pickaxe wrote:
Wood Shovel wrote:
Stone Axe wrote:
Stone Hammer wrote:
Stone Hoe wrote:
Stone Pickaxe wrote:
Stone Shovel wrote:
Copper Axe wrote:
Requires Anivil
Copper Hammer wrote:
Requires Anvil
Copper Hoe wrote:
Requires Anvil
Copper Pickaxe wrote:
Requires Anvil
Copper Shovel wrote:
Requires Anvil
Iron Axe wrote:
Requires Anvil
Iron Hammer wrote:
Requires Anvil
Iron Hoe wrote:
Requires Anvil
Iron Pickaxe wrote:
Requires Anvil
Iron Shovel wrote:
Requires Anvil
Silver Axe wrote:
Requires Anvil
Silver Hammer wrote:
Requires Anvil
Silver Hoe wrote:
Requires Anvil
Silver Pickaxe wrote:
Requires Anvil
Gold Shovel wrote:
Requires Anvil
Gold Axe wrote:
Requires Anvil
Gold Hammer wrote:
Requires Anvil
Gold Hoe wrote:
Requires Anvil
Gold Pickaxe wrote:
Requires Anvil
Gold Shovel wrote:
Requires Anvil
Mithril Axe wrote:
Requires Anvil
Mithril Hammer wrote:
Requires Anvil
Mithril Hoe wrote:
Requires Anvil
Mithril Pickaxe wrote:
Requires Anvil
Mithril Shovel wrote:
Requires Anvil
Antanium Axe wrote:
Requires Anvil
Antanium Hammer wrote:
Requires Anvil
Antanium Hoe wrote:
Requires Anvil
Antanium Pickaxe wrote:
Requires Anvil
Antanium Shovel wrote:
Requires Anvil
Galvanium Axe wrote:
Requires Anvil
Galvanium Hammer wrote:
Requires Anvil
Galvanium Hoe wrote:
Requires Anvil
Galvanium Pickaxe wrote:
Requires Anvil
Galvanium Shovel wrote:
Requires Anvil
Titanium Axe wrote:
Requires Anvil
Titanium Hammer wrote:
Requires Anvil
Titanium Hoe wrote:
Requires Anvil
Titanium Pickaxe wrote:
Requires Anvil
Titanium Shovel wrote:
Requires Anvil
Weapons wrote:
Wood Maul wrote:
Wood Spear wrote:
Wood Sword wrote:
Wood Bow wrote:
Stone Maul wrote:
Stone Spear wrote:
Stone Sword wrote:
Copper Maul wrote:
Requires Anvil
Copper Spear wrote:
Requires Anvil
Copper Sword wrote:
Requires Anvil
Copper Bow wrote:
Requires Anvil
Iron Maul wrote:
Requires Anvil
Iron Spear wrote:
Requires Anvil
Iron Sword wrote:
Requires Anvil
Iron Bow wrote:
Requires Anvil
Silver Maul wrote:
Requires Anvil
Silver Spear wrote:
Requires Anvil
Silver Sword wrote:
Requires Anvil
Silver Bow wrote:
Requires Anvil
Gold Maul wrote:
Requires Anvil
Gold Spear wrote:
Requires Anvil
Gold Sword wrote:
Requires Anvil
Gold Bow wrote:
Requires Anvil
Mithril Maul wrote:
Requires Anvil
Mithril Spear wrote:
Requires Anvil
Mithril Sword wrote:
Requires Anvil
Mithril Bow wrote:
Requires Anvil
Antanium Maul wrote:
Requires Anvil
Antanium Spear wrote:
Requires Anvil
Antanium Sword wrote:
Requires Anvil
Antanium Bow wrote:
Requires Anvil
Galvanium Maul wrote:
Requires Anvil
Galvanium Spear wrote:
Requires Anvil
Galvanium Sword wrote:
Requires Anvil
Galvanium Bow wrote:
Requires Anvil
Titanium Maul wrote:
Requires Anvil
Titanium Spear wrote:
Requires Anvil
Titanium Sword wrote:
Requires Anvil
Titanium Bow wrote:
Requires Anvil
GameCenter: SimenHund - Twitter: SmexyJunkie - Tumblr: SmexyJunkie
Pixelated
(¯`·._.·[ "Tutorial" ]·._.·´¯)​
PostSat Dec 28, 2013 11:11 pm
Doesn't work for Tapatalk :/
GC: XxPixelatedxX
Kik: PixelatedXD
My Shop: viewtopic.php?t=18261
A true member of the JJ Hitman Group "X"
Spymans
Re: (¯`·._.·[ "Tutorial" ]·._.·´¯)​
PostSat Dec 28, 2013 11:16 pm
Good job!
Don't use tapatalk just bookmark the safari page
Spymans, the Ultimate Spy of ANARCHY
Mercenary in The Hitlist
My gc is: The Spymans
SmexyJunkie
PostSat Dec 28, 2013 11:21 pm
And FYI, I will add Crafting Later :approved:
Spymans
PostSat Dec 28, 2013 11:28 pm
Did makin this take a long time?
SmexyJunkie
PostSat Dec 28, 2013 11:42 pm
It did indeed, I think u started like 2 weeks ago :dunno:
DesertEagleHD
  • Location: in a room, in a house, united states, planet earth, somewhere in space
PostSun Dec 29, 2013 12:05 am
This is very helpful.
PostSun Dec 29, 2013 5:06 am
Yes, it is. :0
BetaRabbit
PostSun Dec 29, 2013 5:33 am
i like it =) very useful
BROFIST!
GC: -~<Nycki>~-
No really, who wants a bloody eye?
SmexyJunkie
PostSun Dec 29, 2013 1:40 pm
I'll probably start editing with Crafting Recipes today or tomorrow :approved:
MithrilWarrior11
PostSun Dec 29, 2013 2:16 pm
Nice!
Mithril, the JUDGING leader of the ANARCHY
Leader of The Hitlist
11/27/13...Never Forget
ADD MY GC: 11X11
A True Member of the JJ Hitman Group "X"
Spymans
PostSun Dec 29, 2013 3:43 pm
this might deserve a
sticky?
PostSun Dec 29, 2013 4:07 pm
I hate to say it, but people need to get over the "Oh, I want my topic stickied!!!" Or "This thread should have a sticky, simply because I was the first to suggest it"
Smexy hasn't asked it to be stickied, nor am I inclined to sticky it.
There are already a semi-annoying amount of stickies in most sections, so, we need to think before we sticky.
Also, the way we sticky, is a semi glitch/exploit, so abusing what we have is not a good idea
Spymans
PostSun Dec 29, 2013 4:21 pm
sorry about that
PostSun Dec 29, 2013 4:54 pm
I think the cap should be around four stickies per subforum. General has three, help and support has two. I would consider stickying this there if the author requested it. In the mean time, I'll move this to help and support as the point of this thread is to help people learn the game.
Nice work OP!
