Falling Resistance and Item used for trading.
eatmeimsyko
PostMon Nov 07, 2016 3:21 am
Hi, I played Junk Jack X before, like 2 years ago, i guess. I came back because there is a new update and it was reset. So, I think it is good to come play again because it is a fresh start.
I would like to know which items are good to have Fall Resistance and if it is possible to get 100% fall resistance and bomb/explosion resistance.
Also, I would to like to know where to get that item you use in order to trade. Thanks! :)
*edit*
from what I remember, there's an item that makes you glow (produce light without the use of torch). I would like to know which item(or whatever it is) is that item. THANKS!
deadclown
Re: Falling Resistance and Item used for trading.
PostTue Dec 06, 2016 8:18 am
Unfortunately, I haven't played at all in 2016 and can't help you, but it's disappointing to see that nobody else stepped up and answered your question. Did you try the wiki?
PostTue Dec 06, 2016 12:05 pm
A quick, but annoying if you want organization and stuff, alternative is just to place dirt 2 blocks below on the side of the path youre going downward, then place a platform right below you, then a ladder, then go down.
Im guessing you asked for this because theres now a range limit for placing ladders and torches :P
Ill admit im a bit annoyed by this revalation, but youll get used to it :3
