Where do you get pinecones?
Sportacus
PostMon Jan 02, 2017 2:16 am
I need them
hi
Mage_Knight7301
Re: Where do you get pinecones?
PostMon Jan 02, 2017 4:13 am
The trees from the winter biome(spruce sapling); after the world runs for a bit, the leaves will generate pine cones on them. You can go ahead and fetch them by punching them with your empty hand or cutting down the tree. :approved:
I see you are doing that one thing at that one place at this one time.
Sportacus
PostMon Jan 02, 2017 5:47 am
Thank you so much!
hi
