Painting on Pc
DannySuperNoob
Painting on Pc
PostSun Apr 02, 2017 1:45 am
In the new Junk Jack X PC port, I finally got my hands on paint, but...
I can't paint any objects when i left click on them with my paint bucket. Do I need a certain item to paint with or are there only certain blocks I can paint with?
Thanks.
Re: Painting on Pc
PostSun Apr 02, 2017 2:42 am
Right now you can paint all furniture liners, the glass block, the stain glass window, all wood panel blocks, the craftable carpet, the sloped barn roof, the curtain, and the wallpaper blocks, I think that's it. Unless I missed something?
Natural blocks found in the worlds are not paintable.
XsX
Re: Painting on Pc
PostMon Apr 03, 2017 11:06 pm
Stucco wall and bricks blocks, also vases are paintable. :sisi:
