Luck Potion Recipe
notdattag
Luck Potion Recipe
PostWed Apr 05, 2017 4:38 pm
Hi guys,
I want to craft luck potion but i followed the recipe on JJXwiki (bird feather and vervain bean), i only got potion of cure???
i wonder is the recipe for Luck potions changed and if so, what is the current recipe for Luck potion.
My JJX is ver 3.1 on IOS.
Thanks you
Re: Luck Potion Recipe
PostThu Apr 06, 2017 3:34 am
The recipe is Bird Beak + Feature + Reagent
This reagent can be anything, and this reagent will determin the power of your potion.
The easiest ingredient ive found is the artic pear. I believe it can be found on cryo, given the name, but i honestly cant remember at this point.
It can be grown and produces fruits relatively fast. Simply break the tree if its 2 blocks tall and have a chance to receive more than 2 saplings and start a farm. Either way, this reagent gives 10 "power" to a luck potion, which is pretty big for an ingredient thats easy to obtain
Edit: The plant is in xeno. Articum Pear somethin
PostSat Apr 08, 2017 12:00 pm
Lightbulb wrote:The recipe is Bird Beak + Feature + Reagent
"feature"?
PostSat Apr 08, 2017 5:10 pm
whaddya mean by that?
PostSat Apr 08, 2017 7:20 pm
Lightbulb wrote:whaddya mean by that?
Twelvefoot is just referring to the typo in your post.
You typed the word "feature" but it was suppose to be "feather".
PostSun Apr 09, 2017 7:13 am
ahhh okie. didnt see. haha
xitooner
PostMon Apr 10, 2017 5:07 pm
Funny, I ran into this too; as far as I can tell almost all IOS potion recipes are screwed up versus the JJwiki. As in.... the potion formulas are as legit as ever... they just dont give the right potions the wiki says. Just for fun I followed the chain for a while....
Charm recipe gives Luck
Luck recipe gives Cure
Cure gives Prayer
Prayer gives Health Boost
... and more....
(for what its worth, potions that use the same ingredient twice, like Lava Resistance, and Yellow Color.. dnot seem to be affected)
