Can iOS Worlds Become Android Worlds?
123outerme
PostSun Apr 23, 2017 6:06 pm
Like others who have an Android and used to play on iOS, I'm wondering if the file architecture for worlds the same across both mobile platforms? As in, can I import my world file from when I played JJx (when it was called that) from my iOS stuff to my Android worlds?
GC: 123outerme | "If I'm not me, who's anybody?" - Me | 2nd Signature
123outerme wrote:Edit button. Top right corner. Use it.
Idevenk
Re: Can iOS Worlds Become Android Worlds?
PostSun Apr 23, 2017 9:33 pm
You can use your iOS world on PC so there is a chance it might work.
Have you heard of Junk Jack? Yeah it's pretty cool...
PostMon Apr 24, 2017 1:11 pm
Anything from before version 3.0 is currently not compatible with anything, so no you can't use your old worlds.
But like Idevenk said, worlds do cross between iOS and PC so any new worlds should work across any device.
yikems
PostWed Apr 26, 2017 12:22 am
should.. i would try.. but i quickly looked and did see any folder for junk jack.. Maybe its because i am not rooted.. tho both IOS and STEAM are open wouldnt know why they would close Android
GC: yikems
KiK: Yikem
PostWed Apr 26, 2017 3:30 am
I don't know nuthin 'bout that.
123outerme
PostWed Apr 26, 2017 10:38 am
Yeah, I've been searching around for the data, I think it may only be accessible through a computer or rooted phone. The data may be set to "private".
yikems
PostWed Apr 26, 2017 6:54 pm
123outerme wrote:Yeah, I've been searching around for the data, I think it may only be accessible through a computer or rooted phone. The data may be set to "private".
rooted still dont see it..
GC: yikems
KiK: Yikem
123outerme
PostWed Apr 26, 2017 11:30 pm
I read that most apps keep private data in root/data/data, if you haven't checked there.
Edit: Didn't want to make a topic about this since it's a really dumb question, but isn't smelting using an iron lava bucket supposed to return the bucket? I thought it was, but it used up my bucket for some reason :dunno:
yikems
PostThu Apr 27, 2017 6:51 am
U are right found it... thank you...
GC: yikems
KiK: Yikem
123outerme
PostThu Apr 27, 2017 11:54 pm
yikems wrote:U are right found it... thank you...
Awesome! Someone should add that to the Sharing Worlds stickied post that Stuart made in Your Creations.
PostFri Apr 28, 2017 10:47 am
123outerme wrote:Edit: Didn't want to make a topic about this since it's a really dumb question, but isn't smelting using an iron lava bucket supposed to return the bucket? I thought it was, but it used up my bucket for some reason :dunno:
How is it even possible to melt metals using lava, without melting the bucket that is containig it? :D
PostFri Apr 28, 2017 4:47 pm
Crafting returns an empty bucket, but not smelting. Because if it did you'd have free unlimited heat, I suppose.
