Where do I get Green Marble Slab and Green Dirt?
Apple3001
PostThu May 04, 2017 7:10 pm
Re: Where do I get Green Marble Slab and Green Dirt?
PostFri May 05, 2017 4:59 am
If I'm not mistaken I think you get the slab from Tor and the dirt is from thetis.
Apple3001
PostSat May 06, 2017 9:58 am
Can't find the green dirt on Thetis.
I know it's used to be in underground Seth but I can't find it anymore there. :dunno:
perplexingplatypus
PostThu May 11, 2017 8:14 pm
Mushy green dirt was on Seth, now is on Tor. I get that you're probably looking for normal green dirt-- I cannot find it either. O.o
On a related note, I cannot find black dirt. Anyone know where that is?
PostThu May 11, 2017 11:21 pm
You find black dirt on lilith
perplexingplatypus
PostFri May 12, 2017 2:37 am
Where on Lilith? The surface is grey dirt.
PostFri May 12, 2017 9:39 pm
It's undergound
perplexingplatypus
PostSat May 13, 2017 2:47 pm
Thanks, found the black dirt in the cosmos biome on Lilith. :)
Anyone have a clue where green dirt is?
Adequatepipe
PostWed May 17, 2017 7:52 pm
Found it! Digging underground in Seth! Seems a bit rare, mixed in patches with the Pale Purple Dirt.
perplexingplatypus
PostThu May 18, 2017 5:46 pm
Green dirt is also in one of the biomes on Seth. Just found it today.
Thanks all!
