Android Shop: Bought Miner Helmet not found, where is it?
Sioxx
PostSat May 06, 2017 5:52 pm
I bought the Miner Helmet but cant find the Item or Receipe (what ever that should be, I don't know).
Some other Stuff I bought made no trouble at all, but the Miner Helmet I don't know where to search for.
My Tablet: Samsung Tab A, Android 6.0.1
Greets
Sioxx
Re: Android Shop: Bought Miner Helmet not found, where is it
PostSat May 06, 2017 6:01 pm
Did you click the redeem button in the shop menu?
Once you do that the helmet should appear in your inventory.
If not just say so. Jack or XsX will take a look at it.
Image example: The Giga Blast Helm "Redeem Item" button.
Sioxx
PostSun May 07, 2017 5:58 am
My fault, sorry.
I missunderstood the meaning of the "redeem" Button and did'nt tap it that way. Now I did it and it changed to "redeem Item" and I got the Helmet. All works fine as expected.
Thanks and Greets
Sioxx
PostSun May 07, 2017 6:37 am
Good to hear! :)
Enjoy!
