Help
Help
PostFri May 19, 2017 4:26 pm
I know I've made way too many posts about this but it's kinda getting annoying...where do you find RIGHT chests pieces and what methods would be useful for farming them?Image
Re: Help
PostFri May 19, 2017 4:31 pm
Making new posts isn't going to get you new answers. The blocks that drop them are in the wiki and a quick way to get then is by buffing your luck and throwing tons of explosive down a hole.
Apple3001
Re: Help
PostFri May 19, 2017 4:56 pm
I found one while digging in brown dirt I believe.
Ramsey26
Re: Help
PostSat May 20, 2017 5:37 pm
They drop out of blocks when you break them in the same way that paintings drop. I could trade you one if you want.
Help
PostSun May 21, 2017 7:32 pm
Ramsey26 wrote:They drop out of blocks when you break them in the same way that paintings drop. I could trade you one if you want.
Sure are you on iOS?
