Bucket/Explosive Priority
PostSun Sep 01, 2013 10:29 pm
When you tap on an interactive objects with a bucket or explosive selected, it should interact with that object instead of throwing the explosive or placing the water/acid/lava (that last one will ruin everything).
Re: Bucket/Explosive Priority
PostSun Sep 01, 2013 10:31 pm
yes, but what if a portal spawns in lava. its happened before. then you wont be able to get out the lava and youd lose the portal piece.
Chris
Like addons and chests?
This was also an issue in JJ for TNT until they changed it.
Good suggestion!
FOLLOW & CONTACT ME ON TWITTER
1,400+ days on the forum, and with Junk Jack coming to PC I'll be on almost every day now!
AGE POLL
PIE
Poizone
PostSun Sep 01, 2013 10:34 pm
Second that!! ive flushed half my furniture away when opening doors with a bucket (full of water for my good luck and not lava :asd: :asd: )
g o o d b y e r e a l l i f e
GC: PoiZone
PostSun Sep 01, 2013 10:37 pm
Sollision wrote:yes, but what if a portal spawns in lava. its happened before. then you wont be able to get out the lava and youd lose the portal piece.
Incorrect. You can't interact with a portal or dungeon chest, unless you're using a hammer. So you could still bucket the lava away.
But, if you placed a chest in lava then there would be no way to retrieve the chest, you would be forced to empty it, then hammer it into the lava.
PostSun Sep 01, 2013 10:40 pm
Well, that's not even close to as bad as this...
PostSun Sep 01, 2013 10:43 pm
blonde moment.
PostSun Sep 01, 2013 10:44 pm
@Stu, I know. I did that in the beta. Lava does not destroy the chests themselves. But it will destroy an add on or bridge which is supporting the chest.
PostSun Sep 01, 2013 10:47 pm
Yeah, I remember when lava destroyed all of the chests in your world backup...
PostSun Sep 01, 2013 11:33 pm
Yeah, then later I did it on my up to date world and had to revert to a backup...
