Magical Rope!
Magical Rope!
PostMon Sep 02, 2013 8:57 pm
Have you ever Gone so far around under ground that you lose your trail, your last pickaxe breaks and You cant be bothered digging with your hand up to the surface?
Well not anymore!
Introducing the New Item called the Magical Rope!
Craft: Not sure yet (Maybe chest item?)
You need some sort of magic power for it to work.
you click the screen with the rope in hand and it teleports you to your Spawn!
What do you think?
Re: Magical Rope!
PostTue Sep 03, 2013 12:15 am
Sounds cool.
However, thats why I make two worlds. One world to dig one world to put all my stuff in and craft things. This allows you switch worlds when you're stuck with too much stuff in inventory or run out of tools..
Re: Magical Rope!
PostTue Sep 03, 2013 12:18 am
mastery51 wrote:Sounds cool.
However, thats why I make two worlds. One world to dig one world to put my stuff in and craft things. You switch worlds when you're stuck with too much stuff in inventory or run out of tools..
yup! :)
Re: Magical Rope!
PostTue Sep 03, 2013 1:42 am
:sisi:
BluesClues
Re: Magical Rope!
PostTue Sep 03, 2013 3:57 am
So basically a combination of the magic mirror from terraria and escape ropes from Pokemon? :P
Avatar created by mastery51
Reebz42
Re: Magical Rope!
PostTue Sep 03, 2013 6:42 am
Rope is a bit weird.
What about an intraplanetary portal, made and found the same way as regular portals, except it takes you between two points on the same planet. Obviously you'd need six blocks to use it, 3 to build the portal at home, and another 3 to take with you while mining.
Come to think of it, this might already be possible... Are you capable of entering a portal of the same type as the world you are already in?
It's the end of the world as we know it.
And I feel fine...
Re: Magical Rope!
PostTue Sep 03, 2013 8:05 am
BluesClues wrote:So basically a combination of the magic mirror from terraria and escape ropes from Pokemon? :P
Yep!
Re: Magical Rope!
PostTue Sep 03, 2013 10:32 pm
Reebz42 wrote:Rope is a bit weird.
No, but you can place two sets of portals on a world, enter one, and come out the most recently placed one..
Re: Magical Rope!
PostTue Sep 03, 2013 10:46 pm
:sisi: Let's say you're on Terra.
You build a portal to Seth on the left of your house, then another Seth portal on the right.
You go in the left one, then into the Terra portal on Seth, and you return on the right side of your house.
Sadly it's only one way. With that setup you can't come out the left portal...
Re: Magical Rope!
PostTue Sep 03, 2013 11:37 pm
Wouldn't this be a bit of a copy of the Magic Mirror in Terraria? ^~^ I think you should just be able to craft a rope and use it as a hanging ladder to climb up and down from.
